Hot Rods 8BA distributor conversions
Discussion in 'The Hokey Ass Message Board' started by flatford39, Jan 5, 2017.
  1. flatford39
    flatford39
    Looking for places to have my Chevy distributor modified to run in my 8BA Flathead. I know about Bubba's but if you do a search on them they really don't have good feedback. Are there good alternatives to them or do we just have to stand in line and wait until they work it in???
    I am not interested in an electronic. Points and a condenser are fine with me.
  2. big duece
    big duece
    from kansas
    I have heard nothing but good feedback about Bubba's. If it was negative, it was because he's buried with tons of work.
  3. 3340
    3340
    Charlie ny ,someone here on the H.A.M.B. Mite have contact for him,
  4. VoodooChile
    VoodooChile
    2nd up vote for Bubba. He did my fathers '47. Runs like a top.
    Flatblack 31 likes this.
  5. greazhonkey
    greazhonkey
    I've been running one of Bubba's in my 8ba for 4 years now, never a problem
  6. tubman
    tubman
    I have had direct experience with both "Bubba" and "CharlieNY". If you want a good conversion in a reasonable amount of time, it's "CharlieNY" hands down. If I understand correctly, "Bubba" has moved his operation to his home shop. I don't see how that can help turnaround.
  7. 51504bat
    51504bat
    Charlie did the carb and Bubba did the dizzy on the 8ba in my '39 p/u.. Completely satisfied with both. Your choice.
    RODIST likes this.
  8. deucemac
    deucemac
    If you have an 8BA distributor and a Chevy distributor, plus a basic understanding of how to run a lathe, you can do it yourself. The flathead distributor is for measurements and to use the driven gear on the Chevy shaft. Or the distributors and a good friend with a lathe.
    RODIST likes this.
  9. flatford39
    flatford39
    I don't own a lathe so that is why I am asking for a reliable builder that can turn this around in 4 to 6 weeks.
    RODIST likes this.
  10. flatford39
    flatford39
    How does one contact Charlie NY??? Is there a website or email available???
  11. acme30
    acme30
    from Australia
    Also don't forget it is not just a matter or turning down the chev distributor in a lathe - the advance curve is very different on the flathead to the chev so the advance curve on the chev distributor should be recurved to flathead specs.
    deucemac likes this.
  12. Dak Rat
    Dak Rat
    Good vibes for "Bubba" on my end. Fixed my crappy Mallory flathead distributor and in a timely manor.
  13. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I've used several Mechanical advance Chevy to FH distributors from Bubba and they have worked great.
  14. 40Standard
    40Standard
    from Indy
    I'd have to go to Charlie
  15. PHIL COOPY
    PHIL COOPY
    If you're talking about a window type or a HEI, man they work but look uuuugggllllyyy on a fatahead. Best looking one is a Mallory type Y if you can find one.......opinion. -Phil
    dan c likes this.
  16. RODIST
    RODIST
  17. Kiwi 4d
    Kiwi 4d
    As said Bubba does quality work always. You just have to be patient. I would question poor feedback on work quality. He has many repeat customers.
  18. flatjack
    flatjack
    If you go over to the Fordbarn forum, you will find him there. I highly recommend him.
  19. Bandit Billy
    Bandit Billy
    You didn't ask Flatford, so I hope you don't mind the input, but I used a MSD distributor in my 8BA. It is electronic, which I know you are not into, but it starts easy, runs hard. MSD has black distributor caps now so they look much better. I wanted the electronic advance/retard from the MSD module to avoid detonation issues under boost and their stuff is pretty fool proof. They aren't cheap but compared to having yours customized, maybe not so bad. Looks like the GM unit you desire, you could always rough up the polished bits. Just an idea. Good luck either way.
  20. Kan Kustom
    Kan Kustom
    Bubba is the best . Period !
  21. flatford39
    flatford39
    OK I was contacted by Bubba's (which is fine and I appreciate it) he has a couple of dual point Mallory YL's available at a decent price. I am not educated on this distributor and wonder if it will work OK in my application. Pretty much a 4" stroke 8BA with original cam and to Holley 94's. Not building a race car. Just looking for reliability. Car is a 31 Ford roadster. Never had a dual point distributor in my life so not sure what to do here.
    Appreciate any comments on the situation.
    Thank you.
  22. flatjack
    flatjack
    Do they have vacuum advance? I consider this a necessity for a street diver car.
  23. flatford39
    flatford39
    He says they have mechanical advance. what's the diff??
  24. tubman
    tubman
    Basically, under periods of light load (high vacuum), the distributor provides additional advance which improves driveabilty and fuel economy.
    RODIST and Hnstray like this.
  25. RODIST
    RODIST
    Hi bandit Billy, tks for m s d input, by the looks of ur engine it's no wonder Thaiit
  26. RODIST
    RODIST
