Technical 85 hp trans on 60 hp flathead question
Discussion in 'Traditional Hot Rods' started by birdman1, Sep 27, 2020.
  1. birdman1
    birdman1
    I am installing a 60hp flathead in my 1937 ford coupe. I want to use the 85 hp transmission. I am also using the original 37 closed driveshaft.i did a search, but just confused my old brain even more! Thanks for any help. I recently sold my 1955 tbird, so I wanted ONE more hotrod!
  2. rusty valley
    rusty valley
    the big v8 trannys are different mount pattern. there was however a commercial trans for the 60 that does use the same gear sets as the big boys
    LOU WELLS, woody45 and scrap metal 48 like this.
  3. sloppy jalopies
    sloppy jalopies
    buddy got a nice 60 tranny... listed here on for sale... hope it helps...
  4. birdman1
    birdman1
    I'll look for the listing, thankyou
  5. 42merc
    42merc
    85hp trans will bolt to the 60 horse motor , but the case must be notched for starter c!earance.
    Common fix once upon a time.
    seabeecmc, LOU WELLS and irishsteve like this.
  6. Kato Kings
    Kato Kings
    from Minnesota
  7. firebrrat
    firebrrat
    from Payson Az
    I have a 1940 v8-60 and I bolted it right up to my 39 trans with no problem.
    Sent from my SM-G950U using The H.A.M.B. mobile app
    seabeecmc likes this.
  8. modelacrazy
    modelacrazy
    I have a case I bought at a swap once, it has the cup for the starter that someone notched
  9. Fred A
    Fred A
    from Encino, CA
    1. Upholstery
    The commercial V8-60 trans is a good clean solution to using later Ford and Zephyr gears behind a 60. Too many guys don't get it that the 73-7006 case has to be paired with the correct longer clutch fork or a jam is likely. Make sure you get that special fork! Too many of the hatchet jobs are just that, where using a 78 or other V8 case behind a 60. Cast iron is often difficult to work with. Good Luck: Fred A
