8.8" Ford Rear Ends - Need a width chart - 1939 Ford Coupe
Discussion in 'The Hokey Ass Message Board' started by AHotRod, Apr 6, 2007.
  1. hotrod mike
    hotrod mike
    More good info. Thanks guys Mike
  2. AHotRod
    AHotRod
    Did you find a rear end Mike?
  3. tjm73
    tjm73
    Plus...
    84-92 Thunderbird V6/V8 = same as the 86-93 Mustang 4x4.25" pattern.
    87-88 Thunderbird Turbo Coupe 61.5" w/disc brakes. 4x4.25" bolt pattern.
    84-92ish Lincoln Mark VII & 82-end of rear drive production Continential also 61.5" wide w/ disc brakes, BUT 5x4.5" pattern.
    94-98 Mustang 60.25" w/disc brakes and 5x4.5" pattern
    99-04 Mustang 61-5/8" w/disc brakes and 5x4.5"
    For what it's worth... the Explorer 8.8" is the best in my opinion.
    Here's why.....
    Factory 31 spline axles
    Factory Traction-Lok on the majority of them
    Came with 3.55's at a minimum, but most got 3.73's & many got 4.10's
    Disc brakes
    Integral parking brake (inside the back of the disc brakes)
    4x4.5" bolt pattern
  4. tomslik
    tomslik
    not all exploders had rear disc plus figgure if ya DO get a disc rear it's gonna need e-brake shoes.....
  5. hotrod mike
    hotrod mike
    Well, Steve says he thinks he has one. I just emailed him back. Mike
  6. burger
    burger
    from burbs
    Check out this month's issue of Car Craft. There's an article on beefing up the 8.8 rear.
  7. tjm73
    tjm73
    You are correct. I forgot to say that the disc brake axles showed up with the 94(?) rounded body style and were around till the new body style came out a couple years ago. The earlier Explorer's did have 10" drums and the good axles and ratios and the 5x4.5" bolt pattern too.
  8. coryw
    coryw
    from Omaha, NE
    Pretty sure you mean a 5x4.5" bolt pattern.
  9. tjm73
    tjm73
    Your right! :rolleyes: I edited it. Damn fingers doing one thing with my mind thinking another.
  10. AnimalAin
    AnimalAin
    I concur that 59 inch width is a little wide. The '59 Galaxy rear under mine is about 57 1/2 inches wide and fits like it was built for the old girl. I did run a '67 Mustang rear for a time (about 59 1/2) and it pushed the tires out a bit far.
    One thing to note is that if you are going to run hubcaps, you have a little more room to work with, since there are a bunch of different backspacings available these days.
  11. tomslik
    tomslik
    got a 94 out back with drums but disc MIGHT have been an option...99(i think) is the last year without IRS...
  12. hotrod mike
    hotrod mike
    Thanks for all the replies. Yesterday I bought a '91 Explorer rear. It has discs and 3:73's. I really appreciate all the advice. Feel free to add more if ya want. Mike
  13. Roothawg
    Roothawg
    Sam, do you still have the source for the 8.8 rears?
  14. Did you pass up on a drum brake 8.8? I think my Mustang 8" is going to be too narrow for my 46.
  15. hotrod mike
    hotrod mike
    I asked Steve @Pasco for an Explorer disc brake rear and he had one. I didn't look for drum brake rears. Mike
