I just wanted to clarify something. I have a used 8.8 with 30k on it. It was not L/S Trac Loc etc. So I bought a mustang trac loc unit that was supposed to have around 30k on it. The guy shipped it with the bearings and races, fastened to the side they came off of. I need to use these races with the unit correct? And the caps won't matter...... Also I noticed the races on my unit (original ford) say nothing, his are stamped Timken. Makes me wonder if this unit has more miles on it than I was told and these are replacements??? Thanks Fellas.
When I change carriers, I use the same gears. I will remove the bearings from the old carrier, extract and carefully save the shims. I will then install fresh bearings on the replacement carrier, using the shims, from the old carrier, on the correct sides as original. I have lost track of how many I have done, 40-50 'ish. Zero failures. The Dodge diesel I did in 1996, is still on the road, and has about 350k miles since then. I'm calling that good.
