68 impala rear springs needed
Discussion in 'The Hokey Ass Message Board' started by finch6013, Feb 2, 2011.
  1. finch6013
    finch6013
    from Oregon
    I am looking to replace the rear coil springs in my 68 impala fastback.
    I want to rais the back end up some and was wanting to know if coil springs made for a wagon would fit and achieve the results I am after?
  2. newsomtravis
    newsomtravis
    from pville, ca
    oh crap! here it comes! lookout new guy!
  3. finch6013
    finch6013
    from Oregon
  4. belair
    belair
    Try Google.
  5. finch6013
    finch6013
    from Oregon
    I have been searching and I am just getting more confused.
  6. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    Try rock auto.com
  7. Dakota
    Dakota
    from Beulah, ND
    HOW about you try the right section of thios Board in the Classifieds:Wanted section?
  8. Tony
    Tony
    More than likely, they will fit and bring the back up some.
    However, a good place to ask this would be chevytalk.org. They have specific sections regarding years of cars, and i'm sure someone on there may have done the swap, or could give you some solid advice from experience.
    Best of luck,
    Tony
  9. newsomtravis
    newsomtravis
    from pville, ca
    wow, this must be some kind of kinder gentler hamb!
  10. finch6013
    finch6013
    from Oregon
    I am looking for advice not parts.
  11. Tony
    Tony
    Naa, just rather offer help than be an ass. seems easy enough. :)
  12. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    What's the point anymore. It seems like they are getting worse everyday. It's easier to give them the answer and hope they go away....
  13. newsomtravis
    newsomtravis
    from pville, ca
    hey finch, take ur butt to NAPA and order some springs, simple, done, enjoy...
  14. 65 Imp SS
    65 Imp SS
    from central mn
    I have a 65 impala ss and years ago I did have station wagon springs that I pulled from the junkyard (in the mid 80's) car had a nasty rake and the ride was very rough.
    Currently: if you look in my album you will see the difference between the ride heights. pic with torque thrust d's has std moog back coils with moog 6304 in front could not get the alignment even close (kinda a gasser look)
    Pic with cragar eliminator's has 1"drop front coils and moog cc609 in back. Hope this helps
  15. 65 Imp SS
    65 Imp SS
    from central mn
    Also if you go to Federal Mogul/ Moog site and put info in they will show the different coils available for your vehicle here:
    http://www.fme-cat.com/
  16. When I did my '65 Belair wagon some years ago, I used 409 springs in the back and lopped off a coil from each and it rode fine.
    You'd probably do well with new stock springs and call it done. The HD springs will raise it up even more, but will settle down in time.
    Bob
  17. carmak
    carmak
    I bought new coils for a 65 Impala a few years ago. I had the option of stock or variable rate (I wnet with variable rate). The variable rate springs rode nice empty but got stiffer when I had a bunch of people in it so it didn't sit too low when loaded. I ordered mine 1" over stock and it looked great.
    Carmak
    Riverside, Iowa
  18. roose moose
    roose moose
    My first car was a 68 impala i sold it last year. when I got it the ass-end sat up to high. I wanted it low so when took the coil springs out an aluminum horse shoe spacer fell out from on top of my springs. I put the springs back in without the spacers and it lowered my car about 2". I still have the spacers I dont need em you want them?
