I am trying to take apart my blower snout to have it powder coated, I have removed the back snap ring, is that it ? and press out the front seal & bearing ? Thanks
That is how you get the shaft out. There should be another snap ring at the front of the snout, under the drive portion of the snout. This needs to be removed, then the seal and bearing should come out. You may have to heat the snout to get the bearing out.
