Hot Rods .
Discussion in 'The Hokey Ass Message Board' started by plumbid, Dec 30, 2011.
  1. Looking great!
    Sam
  2. Canvas white, first name looks to be Chuck, last name Taylor?
    [insert picture of vintage Converse Hi-Top here]
  3. sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet
  4. OahuEli
    OahuEli
    from Hawaii
    Looks like your cam and valvetrain setup will provide a good base for experimentation when you get to that point. You can always replace this cam with one that has more lift & duration down the road. What compression ratio are you running now?
  5. My thoughts are that you should worry about it "just going" at first. Just like me last year with my Henry J, the first time down the track was a little nervous. I didn't know if it would go left - right or straight off the line. Will it have death wobble at speed ? What if it pulls left or right when I hit the brakes ?
    Lots of other stuff to think about than just going fast, you can always go faster after you get going.
  6. OahuEli
    OahuEli
    from Hawaii
    Yup, you can always change the cam, and with the CR you're running the blower ought to like it.
  7. 1971BB427
    1971BB427
    from Oregon
    I just put the same exact cam in my 327 powered Austin. I also went with a pair ofaluminum head with 195cc runners, 64cc chambers, and 2.02/1.60 valves, and 1.6 roller rockers. Probably a little over .500" lift with the 1.6 rockers. My engine is 9.5:1 CR.
    It's a great sounding cam and runs out well, with good midrnage to high end power, but a little lacking in the under 2500 rpm range. Not a dog, but I can definitely feel it coming on stronger after 2500 kinda like a two stroke engine.
    I'm running a th350 with 2500 stall, and I'd guess you'll do better with the stick in your coupe.
  8. n847
    n847
    I'm interested to see how it goes! I have a mild 350 bored 60 over with 194 valve heads and I have looked at the same cam for it! I'm just getting it all back to gether to get it on the road and I'll look around for a new one this summer!
  9. OahuEli
    OahuEli
    from Hawaii
    Checked the cam specs and it refers to a midrange to high end so it looks like your cam is working like it should. If the cam "comes in" at 2500 rpm don't expect much below that. If you run a slightly higher stall the motor should be "on it" by the time you get lockup. Or just switch to a 4 speed, they're way more fun anyway!
  10. 1971BB427
    1971BB427
    from Oregon
    I'd love a stick, but my Austin barely has room for 2 pedals, let alone 3!
  11. steamer
    steamer
    Nice, is that a '63 like mine? I dig the new fuel cell in the back of the coupe. You are right, big swap meets are startin' to happen back East, NY,PA and the area. Keep us fed with project info.
  12. Hogman
    Hogman
    from Dallas, TX
    Great build thread, nice work
  13. 1971BB427
    1971BB427
    from Oregon
    You have a '63 and don't recognise the rear of a '64? ;)
  14. rustednutz
    rustednutz
    from tulsa, ok
    That's not a fuel cell, silly. That's his new supercharger.
  15. n847
    n847
    Damn I hope your getting done with those brakes I'm ready for some more updates!
  16. Beau
    Beau
    Lookin good! Can't wait to see it around town.
  17. n847
    n847
    Looks pretty good to me. Those master cylinders are a tidy set up! What kind of calipers are you using? Did you make the caliper brackets?
  18. n847
    n847
    Good to know!
  19. Sprocket71
    Sprocket71
    from Anna, Tx
    Gassers are sickalicious!
  20. Noland
    Noland
    Looking great. First time Ive ever seen this thread. Awesome gasser.
  21. Shamedevil
    Shamedevil
    You should be proud of all the hard work you put into that car....it really looks sharp....buy yourself a case of Corona!:D
  22. love it, keep the pics coming!
  23. n847
    n847
    well done! So with 2 weeks off we can expect this thing to be about done at the rate your goin!
  24. straightaxle65
    straightaxle65
    Corona will work but your in Minniota.............Get a case of that good ol' Grain Belt!
    Fresh from New Ulm !
  25. straightaxle65
    straightaxle65
    Ah! Good Man. Same here, I love the taste of Grain Belt and it doesn't give me a hang over. I guess the bad part about that is I tend to drink more!
    That being said, You have a great project going there! Keep up the great work and look forward to seeing it done!
  26. steamer
    steamer
    Great stuff, you do a lot of cool stuff. I dig the home built way. Keep it coming, hope to do the same soon on mine.
  27. I like the bung with stud weld on the axle housing...I need to finish my current projects so I can build an early car like yours....really looks great and everything a Gasser should be....
  28. n847
    n847
    Nicely done good n clean!
  29. farmer12
    farmer12
    This build is coming along nicely, well done! Given you a big 5 stars my friend.
  30. OahuEli
    OahuEli
    from Hawaii
    I can see your point about getting an axle out of an old truck. At least you know for sure its not some POS Chinese repop with metric machining.
