Projects 65 Ranchero Southeast Gasser build
Discussion in 'Traditional Hot Rods' started by colbyw, Dec 28, 2017.
  1. Hang'emHigh
    Hang'emHigh
    I have 100's of pictures of the metal work on mine. Countless hours. And you can't tell without a sharp eye, lol. But that crap needs done and done right. We know what you're going through. Now get back to work! I want to see this thing making passes.
    loudbang and colbyw like this.
  2. catdad49
    catdad49
    Hey, you're checking things off the list. It'll be time to fire it up before you know it!
  3. colbyw
    colbyw
    [​IMG][​IMG]
    The body is off
    postman99, enloe, loudbang and 3 others like this.
  4. Gammz
    Gammz
    from Lincoln Ne
    New quarter panel? And what’s the story on the car in the background!?
  5. colbyw
    colbyw
    Someone long ago replaced it and overlapped it, long story short we cut it off and butt welded it back on. But the car in the background belongs too the previous owner of the ranchero. It had sat for a while and I got it running and took it too a few car shows and learned how too drive the 4-speed in it. Plan on returning it too the track in the spring.
    loudbang and Gammz like this.
  6. colbyw
    colbyw
    [​IMG][​IMG][​IMG]
    Sent the car off today too get it blasted should have it back by the weekend .
    OahuEli, loudbang, Gammz and 2 others like this.
  7. Hang'emHigh
    Hang'emHigh
    Like the lightening holes on the inner rockers. Was that rust repair done inside the bed?
  8. colbyw
    colbyw
    No it’s Not done yet we’re leaving it long until we get tubs ,there’s still metal work too do but we had too get it too the sand blaster this weekend in order to get it back before Christmas break.
  9. colbyw
    colbyw
    Welded all the brackets on the rear end waiting for parts too do the panhard bar then it’s ready too be narrowed. Spending the rest of the day welding the frame up.
    catdad49, loudbang and Hang'emHigh like this.
  10. rawcjw19
    rawcjw19
    [​IMG][​IMG][​IMG]
    You should tell everyone how you forgot to take your doors to the blaster.
    EVL401, catdad49, weeniewawa and 4 others like this.
  11. colbyw
    colbyw
    [​IMG][​IMG]
    Got the car home last night from the blaster, hopefully the body work doesn’t give us any trouble
    catdad49, Gammz, loudbang and 2 others like this.
  12. Hang'emHigh
    Hang'emHigh
    Not the most glamorous work, but well worth it. Reminds me of mine at that stage. Felt like we were over the hump and headed for home. Little did I know, lol
  13. 6sally6
    6sally6
    Ohhhhhhh...IF I could only get down on the floor(or squat down) and do welding like that! I once could but.........now not so much.
    I would need it all jacked up on a table for me to weld it up now.:(
    6sally6
    Atwater Mike and loudbang like this.
  14. colbyw
    colbyw
    [​IMG][​IMG]
    Got some of it in epoxy too keep it from rusting, plan on doing some more this weekend along with some more welding on the frame.
    brianf31, saltflats, loudbang and 3 others like this.
  15. colbyw
    colbyw
    Finished the shock mounts and panhard bar so I could take the rearend too a local shop that has the right tools too narrow it.
  16. rawcjw19
    rawcjw19
    That’s not how I would have done it
    Doctorterry, Hang'emHigh and colbyw like this.
  17. colbyw
    colbyw
    [​IMG][​IMG]
    After about 2 days of prep work the whole body is in primer, we spent today getting the doors ready for paint.
  18. colbyw
    colbyw
    Painted the engine and still just knocking out the body work, the doors are done and the rest of the body minus the flipfront and tailgate should be done by the weekend.
  19. Doctorterry
    Doctorterry
  20. loudbang
    Looks like stock 260 Ford Gold paint. :)
    deathrowdave and enloe like this.
  21. Brian Penrod
    Brian Penrod
    Sweet build!
  22. tpw35
    tpw35
    Where did you get the wheelie bars? Is that a kit?
  23. colbyw
    colbyw
    We made them, got the heim ends and wheels online and the aluminum we just had bent by a guy with an English wheel.
    The steel rods have threaded bungs welded into the ends.
    brEad, Gammz and loudbang like this.
  24. rawcjw19
    rawcjw19
    We copied the design from SEG pictures
  25. tpw35
    tpw35
    Thanks, I need to make a set.
  26. tpw35
    tpw35
    How close does the pinion angle need to be prior to welding the spring floater brackets on, how much adjustment do you have once they are in place?
  27. colbyw
    colbyw
    We set the pinion angle with the car at ride height and the rear end blocked in place, and then welded the floater brackets on. With the adjustable ladder bars there should be quite a bit of adjustability of the pinion angle but we never actually measured it. The engine block and pinion are set straight in line with each other. This may not be the right way too do it it’s our first one like this using the floater style setup.
  28. colbyw
    colbyw
    [​IMG][​IMG][​IMG]
    Got the rear end back from being narrowed and put it in with the new shocks, and built a battery box. Got the new rear brakes in and ordering axles soon.
    brEad, saltflats, enloe and 4 others like this.
  29. colbyw
    colbyw
    Made the front shock mounts and welded them in place.
    enloe, loudbang, Gammz and 3 others like this.
  30. colbyw
    colbyw
    [​IMG][​IMG]
    Getting all the bodywork closer too being finished.
    enloe, brEad, Gammz and 1 other person like this.
