Technical 65 170 Ford rear main oil seal replacement
Discussion in 'The Hokey Ass Message Board' started by neilswheels, Jul 22, 2021.
  1. neilswheels
    neilswheels
    from England
    Looks like my trucks got a leak. I’ve had a rummage around the net, but can’t find anything. Is it a split seal, rope or modern, can I replace it by dropping the pan, or is it engine out? Appreciate any help
  2. neilswheels
    neilswheels
    from England
  3. squirrel
    national 5116 or felpro bs30135 are split rubber, to replace the rope seal, but seem to be out of stock at parts stores right now.
    rope seals are tricky to replace without pulling the crankshaft, so engine out. If you can find a rubber seal, it should be something you can do without engine removal.
