Hot Rods 64' Galaxie build sheet decode!?
Discussion in 'The Hokey Ass Message Board' started by Nellynel07, Mar 30, 2017.
  1. Nellynel07
    Nellynel07
    i found my factory build sheet for my 64' Galaxie country sedan wagon and I can't get everything decoded.
    I know somewhere out there in deep dark depth of the internet a website or forum has my answer posted but honesly this is more fun so please spare me the shameing.
    I have most of it I think but let's see what the experts come i with!
  2. mgtstumpy
    mgtstumpy
    ROT - 057
    'Rotation number'. The car's position on the assembly line on the day it was built. That car was the 57th car in line on the day it was built. That number may be scrawled in white paint stick on the firewall under the heater box. The ROT appears to have allowed the assembly line workers to match up the build sheets with the bodies as they travelled down the line.
    Serial number - 4P72V178692
    4 - YOM [1964]
    P - Built at Twin Cities, MN
    72 - 6-Pass. 4 door Country Sedan
    V - Engine, 6cyl -223ci
    178692 - Sequential number, commencing at 100,001. Location: Full Sized Ford - Stamped into the extension tab on the right side on top of cowl under hood.
    Patent plate code - 71B 4-Door 6-Pass. Country Sedan
    Paint - F - M30J-1622 Med. Blue Met Guardsman Blue
    Trim - 42 - Mosaic Vinyl and Crush Vinyl, Med Blue Met. and Lt Blue Met.
    Type order - 2????
    Schedule date [Of build] - 21 April
    Region District - Salt Lake City, Utah
    Axle - L8; - Equalock 3.89:1
    Drive shaft - A; Appears that driveshaft with part number and 'A' suffix was used
    Radiator - M; Appears that radiator with part number and 'M' suffix was used
    Car line - F; Ford (Full size);
    Springs - Front - H; Rear - A Appears that springs with part number and 'H' and 'A' suffixes were used
    Shocks - A Appears that shock absorbers with part number and 'A' suffix was used
    Engine - V 6 Cylinder 223 Cubic Inch
    Trans - 1 3 Speed Manual-Shift
    Tyres - Size - T ????
  3. thunderplex
    thunderplex
    Excellent job...!!!
  4. Does it tell what the assembly line workers had for lunch that day?
  5. Nellynel07
    Nellynel07
    See and this is why I love this forum. Wealth of knowledge and perfect answer!
    Thanks you!
    I'm going to print that off and keep with my build sheet forever!
    Thanks again!
