so i searched all over and im having some trouble. i bought a 1964 fairlane wagon and someone cut alot out of the front coils and it is a little to low for an every day driver. the front tires rub and it bottoms out alot. i cant really find any new springs and im wondering if there is any other spring i could use. the only springs i found were $200 and it said 2-3 weeks to ship. i would like to find stock ones and cut just 1 coil out, i only want it about 1 inch lower then stock. i know about all the problems with installing them. thanks.
I am in maryland, I purchased mine from our local shop...Fallsway Sping.. They will make whatever you need. Check your area for spring shops. The mustang spring I believe is not rated the same as a fairlane. I might be wrong , but for some reason I think my best friend tried it...
well i still got no luck finding anything so if any one in the cleveland ohio area has some send em my way.
http://www.eatonsprings.com/ I've read good things about these guys. Never dealt with them personally, though. KRH
