Technical 64 caddy 427 in model a
Discussion in 'Traditional Hot Rods' started by 1929sedanrod, Nov 10, 2014.
  1. 1929sedanrod
    1929sedanrod
    I'm looking at a 1964 caddy 427 and a turbo hydromatic trans read it was a one year only with a variable speed converter? Will this set up work in a 29 ford sedan or will it shift weird they sell adapters to put standard gm trannys behind it or will I be ok with the original trans
  2. squirrel
    429? The Variable Pitch 400 works like a normal one, with the addition of variable torque converter stall speed. You can leave it disconnected and have it be stuck in "low stall" all the time, or put a toggle switch and feed it 12v when you want "high stall". The difference in stall speed with a stock torque converter is only about 500 rpm. I have these things in all my old Chevys....love them!
  3. 1929sedanrod
    1929sedanrod
    Yes 429 .... At work we had a buick nail headwith a varable converter and had problems changed to a regular converter no problems also didn't know about a switch you are talking about
  4. 1929sedanrod
    1929sedanrod
    Anyone know about a buick dynaflow 1962 would I have problems with weird shift patterns in one of those?
  5. txturbo
    txturbo
    not sure what you mean by "shift weird"
  6. 1929sedanrod
    1929sedanrod
    The buick with the variable converter shifted weird and would almost fight it self stopped in gear the tranny shop said because it was designed for a 4000pound car not a 1800 pound car and was a converter problem????? Just don't want to have that problem again
  7. txturbo
    txturbo
    ...if I were using a caddy 429 I would just get a regular turbo 400 to put behind it that uses a regular convertor.
  8. 1929sedanrod
    1929sedanrod
    Yea the adapter is 525 pluss a starter tryin keep it cheep
  9. txturbo
    txturbo
    shouldn't need an adapter.....find a caddy turbo 400 from 65 or later
  10. 1929sedanrod
    1929sedanrod
    Crank bolt pattern diffrent need to change crank and machine block for a starter I was told 64 starter bolts to trans 65 bolts to block
  11. squirrel
    So you don't know if the problem was because it was a switch pitch converter type transmission, or if it was because there was something wrong with the transmission? I guess it's pretty easy to just say "they're all junk" than it is to fix whatever is not working correctly.
    Having the variable pitch converter gives more stall speed, that's a good thing. But you have to install it properly, so it works. It's not difficult.
  12. iafraser39
    iafraser39
    from Warmland
    I have a switch pitch T400 in my Model A and it works fine.
    You can disable the solenoid that activates the switch pitch
    if you have problems. Its not a big deal.
  13. 64THStarter1.jpg 64 starter support bracket
  14. krazee
    krazee
    I'm running a '64 429 from a Fleetwood in my '29 Chev, can anyone post a photo of the harmonic balancer installed, someone has installed a bolt into the crank to hold it on. I pretty sure it doesn't need this as the balancer is a press fit. The 390's up to '63 did need the bolt. Thanks for the photo of the starter mount front support, mine didn't have one.
    Has your engine got a factory adaptor between the engine and the trans, I believe they were installed after a factory fire destroyed the assigned T4oo's so they used Buick pattern units.
