History 64/65 Comets old drag cars lets see pictures
Discussion in 'Traditional Hot Rods' started by apound, Feb 17, 2009.
  1. Scored an Econoline axle complete, working on removing 5 1/2 inches out of the middle. gonna tweak the rear fenderwells a bit, maybe a bigger rear axle, and I have a killer set of ladder bars built for a project such as this I've been hoarding!! Might jump up to a 390 when I can eliminate the inner fenders,with white fenderwell headers. Gotta have the piecrusts too. Towel City retreading in Kannapolis is making them.They're just up the road !!
  2. teddisnoke
    teddisnoke
    from So Cal
    It'll be a bitchin ride! Did you score the springs and perches as well? With the added heft of the 390, you may need to add a leaf or two to the spring pack.
    Last weekend, I got a back-to back ride . My Comet against a big block Nova, with the Nickey Bill Thomas axle set-up, which I believe sources some of their parts from Speedway. Had it not been for the added heft of the all-iron Rat motor, those short springs would make a long trip a bit bouncy. Remember, the longer the leaf spring, the better the ride...:)
  3. ClearSpot
    ClearSpot
    from Michigan
  4. MUNCIE
    MUNCIE
    from Houston
    I got a question for us ford/mercury guys. When converting to alternator from generator on a sbf is it always necessary to drill and tap the bolt hole on the head.My reason for asking is currently I have a gm alternator for mock up with the spacer and washers stacked.
    I have notice that the Ford alt has the housing with the additional space.This would eliminate the washers but I am not sure about the bolt hole size for the ford alternator?
    Thanks,
    Mark
  5. JunkYardFrog
    JunkYardFrog
    from CA
  6. teddisnoke
    teddisnoke
    from So Cal
    Taken from a Facebook post. This may have been put up here before.
  7. 65COMET
    65COMET
    Mark;most GM alternators use a 3/8" top bolt,Fords use a 7/16" top bolt.You can easily drill out the hole,then make a longer spacer.Just did one last month for a friends 64 Fairlane. ROY.
  8. teddisnoke
    teddisnoke
    from So Cal
    Here's what dropping the oil pan produced:
    The cap still looks fine, but the crank will be a ballast weight from here on out.
    Also- a big THANKS to fellow racer and friend, Roy, for sourcing me a replacement crank suitable for my '64.
    The rest of the engine appears to be fine, but will still get a complete R&R due to the small bits of debris possibly floating around...
    Dale
  9. Dale:
    Got the new Pie Crust in from Towel City, Hope to see some smoke soon!!!!!
    Fast Eddie
  10. teddisnoke
    teddisnoke
    from So Cal
    They look nice! What pressures do they suggest running?
    By then way, cute model you hired !!!
  11. Dale:
    They said around 32 psi, I'm gonna just use them for street/car show use, I have my new M and H's for the racing scene. Crazy how quik my baby's growing :(
    Fast Eddie
  12. mercuryjunky
    mercuryjunky
    from arvada,co
    Cool Video of the build of Jack Chrismans 65 comet by Chrismans Garage.
  13. teddisnoke
    teddisnoke
    from So Cal
    Did I hear a rumor there is another Comet on the cover of this upcoming month's CarCraft?????????
  14. I hope it's a vintage burgundy 64 falcon soon!
  15. teddisnoke
    teddisnoke
    from So Cal
    I need pics, Mike!!! Of the "other "car!!
    Seems the rumor is TRUE!!!!!!! Hoffmans car is on the cover of this month's upcoming CarCraft!!!! Can't wait for the read...
    Dale
  16. Check and make sure the torque converter snout isn't bent and it is in balance if the car is an automatic. A friend did the same thing and that was the problem . Also make sure the converter is completely on the sprag or it can load the crank and " grind " out the thrust bearing.
    Rob
  17. Mumbles
    Mumbles
    from PNW
  18. 65COMET
    65COMET
    Mumbles;Thanks for posting that!! Some of those pictures have been on here,still great to see!! ROY.
  19. MUNCIE
    MUNCIE
    from Houston
    Roy,
    Thanks for the information.I am going take a look at it this weekend and see if I can get it done.Did you do this why the engine was installed or was it on a stand? By the way is your friend running the GM alt or the Ford.
    Thanks,
    Mark
  20. 65COMET
    65COMET
    Mark;we did it at the Drags between qualifying rounds!!!Used a cordless drill with a 7/16" bit,he already had it setup for a GM one wire using Ford brackets.We bought a rebuilt alternator from a vendor,all he had were ones with the 3/8" hole! ROY.
  21. MUNCIE
    MUNCIE
    from Houston
    :eek:Roy,
    Thanks!! I didn't realize it was between rounds:D That is the set up I have now but with a ford spacer and a bunch of washers to make up the difference.I got a cousin I need to get in contact with who is a machinist,that way I'm hoping he can make me my own spacer.I'm going give it a shot this weekend!
    Mark
  22. 65COMET
    65COMET
    Mark;I have had great luck with those alternators,have put them on dozens of old Fords either to replace a Ford alternator or generator!!! ROY.
  23. Judd
    Judd
    Weighed the Comet door today less interior panel. 65 lbs with glass and regulators etc. Installing Plexiglass windows.
      53.5 KB
      49.9 KB
  24. ec164
    ec164
    from MI
    Your car looks pretty cool Judd!! Al
  25. teddisnoke
    teddisnoke
    from So Cal
    The Mercury sickness continues:
    Why........
  26. JunkYardFrog
    JunkYardFrog
    from CA
    Why not???
  27. JunkYardFrog
    JunkYardFrog
    from CA
    So what engine is in it now?
    And what future plans do you have for your new toy?
  28. teddisnoke
    teddisnoke
    from So Cal
    Original 390, a 351 Cleveland in it now, get it fired back up, and re-sell it to a Ford purist.
  29. AFX DAVE
    AFX DAVE
    I have a 66 Comet I am putting back together, it's 3300# with a 467ci FE,
    With a Built C6 Trans, 31 x 10 1/2W. With a compleat Mark Willams drive train. Suppost to have it at Milan Dragway in May 19 at the Detroit Dragway Reunion??? Trying to get the 65 BFX Comet back together I haven't run it at a Dragstrip in a few years.
    Dennis K. Is going to be there with his Bob Ford "T" Bolt
    ~~~~~~~~AFX DAVE~~~~~~~~
  30. ec164
    ec164
    from MI
    That sounds great Dave, I will plan on being there that week end. Sounds like a good time and will get to see a bunch of Ford product. We can get some new Comet photos for the thread to see. Al
