Hi everyone My dad just picked up 63 Ford ranchero. We were hoping anybody has pics how they mounted the clutch pedal equalizer bar? The piece that connects between clutch pedal to throw out bearing arm. Also if anybody has photos of the shifting linkages from column to the transmission? As well any idea where we can source the linkages?
Most falcons had a "fixed" length rod between the equalizer bar and clutch fork. The adjustment is made at the upper threaded part that runs from the clutch pedal to the equalizer bar. Linkage and setup will be determined by which engine you have.....a 6 cyl or 8 cyl.
The Z-Bar needs a mounting bracket (for the ball pivot mount) that sits on top of the frame rail. go to Falconparts.com
