Make sure the v8 bellhousing is from 1960-62. It has the slave cylinders you will need to work in your '62. I ended up using all the parts from a '63, and converted it to manual linkage because I couldn't find the correct bellhousing. Dave
My '63 PU had a hydraulic clutch. At one time, I had a '62 Suburban and a'62 PU but don't remember if the clutch was hydraulic or linkage. I do remember the '62's had torsion bars in the front and not coil springs like the '63 had.
