Projects '61 Falcon Street/Strip Gasser Build
Discussion in 'The Hokey Ass Message Board' started by brianf31, Nov 14, 2019.
  1. brianf31
    brianf31
    Foot space will be tight with all the engine setback.
    catdad49, Thor1, oldiron 440 and 2 others like this.
  2. southcross2631
    southcross2631
    you've got lots of room. I had to bend my down tube out in the front of my cage so I could have room for my leg to work the clutch pedal. It gave my 2 more inches of foot space.
  3. woodhawg
    woodhawg
    1. S.F.C.C.
    Hi Brian. Just found this. Watching. Good work.
    Woody
  4. Looking Great!
    BigMike
    Thor1, brianf31 and loudbang like this.
  5. brianf31
    brianf31
    I moved the engine forward 1" and cut the cowl to make install/removal easier. I lowered it 1.5" so that the crank centerline is at 18.5" from the ground.
    Roll cage welding is mostly finished except for the door bars. The front roll cage tubes really stiffened the frame up. It doesn't have any noticeable twist when you offset jack it.
  6. brianf31
    brianf31
    You know al those old headers you have lying around? Yeah, you might as well throw them away because they will NEVER fit your current project. Guaranteed.
    I built these for my A coupe but never ran them. I'll cut off the flanges with stub and reuse them.
    Deuces, catdad49, Thor1 and 4 others like this.
  7. brianf31
    brianf31
    Boy these wheel wells are tight. They are tall but narrow front to rear. I initially centered the marking template at the stock axle centerline. It was evident that I wouldn't have enough clearance at the front so I shifted the cut back 1".
    I used a 15" radius with the center shifted up 1" from the bottom of the rocker line. With a ride height of 14" from ground to rocker and a 28" tire, I'll have 2"+ vertical clearance and 1" clearance front and rear. The front edge of the cut is right at the front edge of the inner wheel well.
    Deuces, fauj, deathrowdave and 8 others like this.
  8. southcross2631
    southcross2631
    Looking serious. I like it.
    Thor1 and brianf31 like this.
  9. brianf31
    brianf31
    Thanks, southcross.
    I'll move to rear suspension soon. I'm debating traditional ladder bars (made from 1" round) versus rectangular tubing with a top round link like you are running. That set-up has the advantage of dialing in pinion angle while maintaining hole concentricity with the rear end brackets.
    What size and wall thickness did you use? 3/4" rod end?
  10. southcross2631
    southcross2631
    Yes , I used 1 " round roll bar tubing for the top bars and 3/4 rod ends. I bought the weld in sleeves .
    My bars are my version of the Stott bars that Quain uses.
    It allows more adjustability as far as wheelbase , pinion angle, instant center adjustments.
    Are you going to use leafs or coils ? Coils are lighter and easier to change spring rate . DSCF3465.JPG
    Deuces, catdad49, Thor1 and 2 others like this.
  11. brianf31
    brianf31
    I'm thinking leaf springs for a more traditional look, though I realize its limitations.
    I'll need axle floaters. How does this style with rollers clear the leaf spring clamp pin?
    Maybe Chris Alston's slotted version is the better way to go.
    Deuces, Thor1, Fiddle Picker and 2 others like this.
  12. brianf31
    brianf31
    Speedway 4" drop straight axle install is under way.
    fauj, catdad49, Thor1 and 3 others like this.
  13. southcross2631
    southcross2631
    Speedway's hot rod column works good too. It comes with a quick release for the steering wheel and can DSCF3480.JPG be ordered in the length you need comes a double D at the other end. Saves a lot of time and fabrication.
  14. brianf31
    brianf31
    Great tip. I'll try that if I can't get the stock column to work out.
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
    Thor1, Fiddle Picker and loudbang like this.
  15. boutlaw
    boutlaw
    Awesome build Brian, subscribed.....the FE in my Ranchero is moved back about a foot, requiring doghouse in cabin with removable panels to get to rear plugs and header bolts, be advised that steering column position can make for some serious twisting under panel to get to those items, and removable panels need to be as large as possible. Thought mine were big enough, but they definitely are not.
  16. southcross2631
    southcross2631
    This is the dog house in my old Falcon. the 289 was moved back 10 inches. It had a Lexan cover in the middle. Came in handy you could see the motor through the cover going down the road. Found a plug wire arcing on a header one night coming home from a cruise in. 2013-10-10 11.57.43.jpg
  17. brianf31
    brianf31
    Now that is cool. I might have to borrow that idea.
  18. boutlaw
    boutlaw
    that is a cool idea, wish I had thought of that....
  19. Fiddle Picker
    Fiddle Picker
    Just saw this on the HAMB. Looking great !! Following along.
  20. brianf31
    brianf31
    Suspension mock-up reveals that I need to pull the axle back an inch or so. It's kinda close at the front of the fender opening and looks more like an Altered than a Gasser.
    Tim, catdad49, brEad and 3 others like this.
  21. brianf31
    brianf31
    Fiddle Picker gave me a lead on a '66 Toploader. The internals look great and for $500, it was a pretty good deal. I'll upgrade to the big input and output shafts.
    -Brent-, catdad49, Thor1 and 6 others like this.
  22. sonic03bluegt
    sonic03bluegt
    from sc
    The top style will work better with what you're doing in my opinion. My falcon always 60' better on leafs than it did with coils
  23. oldiron 440
    oldiron 440
    I thought I read somewhere that the suspension could only deviate 1" from stock.
  24. brianf31
    brianf31
    Correct. I moved the rear axle back 1" and I'll put the front axle back to stock location. It's 1" forward at the moment.
  25. southcross2631
    southcross2631
    That 1inch is from either axle so a total of 2 inches is allowable . That's what Quain told me when I was building my Morris and when you start with an 87 inch wheelbase car like I did every little bit helped.
  26. southcross2631
    southcross2631
    Liberty will take your small input shaft and cut off the splines and replace the shaft portion with a 300 M shaft for 325.00 or you can get a combo where they will faceplate it and replace your synchros and make it a crash box for 90.00 more.
    that's what I am doing to my toploader. Takes about 3 weeks. They told me it will take a lot of torque and horsepower. That way you can reuse your input retainer and small block clutch fork.
    Thor1, Fiddle Picker and brEad like this.
  27. brianf31
    brianf31
    Sounds like a more cost effective way to go.
  28. southcross2631
    southcross2631
    Liberty's Gears phone number is 586-469-1140. Ask for Paul.
  29. brianf31
    brianf31
    I moved the axle backed 1". It will be about 1/2" forward of stock location when under full load.
    Tim, catdad49, Thor1 and 2 others like this.
  30. brianf31
    brianf31
    I bought a Mittler Bros. 36" throat, 16 gage capacity bead roller for the shop at work. I can't wait to use it on my own panels. Bead Roller.jpg
    fauj, catdad49, brEad and 4 others like this.
