Projects 61/62 swb uni
Discussion in 'The Hokey Ass Message Board' started by Wanderlust, Oct 27, 2019.
  1. Wanderlust
    Wanderlust
    9949B06C-FD3E-4793-A78A-BA34C2B0E94D.jpeg been working on this for about a year, getting close to having it road worthy
  2. turned it for ya. So what have you been doing to it? We love pics and stories....:)
    Randall likes this.
  3. williebill
    williebill
    Always liked those trucks. What's under the hood?
  4. Wanderlust
    Wanderlust
    9BA65DCD-9DB1-4E19-A7AC-4147889542E2.jpeg 39FE3448-13AC-467F-A5FD-4D85276B2864.jpeg Thanks vtwhead, will have to learn a few thing about posting. Posted a pic in sitting and rotting of it when found almost 2 years ago, took a year to be able to get it out, too wet and farmer had ripped out plugged culvert to drain land.
  5. RmK57
    RmK57
    Turned out pretty nice. Nice save!
  6. goldmountain
    goldmountain
    Years ago I worked one one of these trucks that was chopped and channeled. It was a real neat looking piece.
  7. Wanderlust
    Wanderlust
    1A93F4C6-13B9-4C1A-941A-99DC3499F6EA.jpeg 5E106080-0675-4B9F-913A-DBB620F86443.jpeg 5BE081DD-F6E8-4363-B6ED-9FEE7E173125.jpeg Thanks RmK57, am pretty happy with how it’s turned out, after getting it home, cleaned up and having a good look at things, it was a bit further gone than I thought. At that point decided to just get on the road, rust is into the seams so I don’t have the budget to blow it all apart and fix it properly, I cut out the majority of the rust and welded patches, replaced 70 % of the cab floor, pounded out most of the dents. Painted the patches but thats the extent of the bodywork lm going to do.
  8. Budget36
    Budget36
    Buddy of mine had one when we were in HS...late 70's, the 352 tossed a rod and we found a (I think) 70 LTD with a 390 we swapped in. Dang truck ran pretty good after that.
    Have fun with it, looks like you're up for it!
  9. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Looks good.
    I can't drive mine anywhere without questions.
    I especially love the "my grandpa had one just like that" and then they follow with "How did you weld the bed and cab together?"
    john walker and Frankie47 like this.
  10. Wanderlust
    Wanderlust
    68468350-47F4-48C4-8549-EF998F3D9B8D.jpeg The truck came with the 223 which was surprisingly not stuck and 3 in the tree, lots of parts had been robbed off of it, the pumpkin and axles, wheels. I was not too concerned as I had a 64 doaner at home with a 292/3 spd, that being said, it’s amazing how many subtle differences between the two trucks, obviously the body but I’m talking all the little things, bolts, screws, wiring. I did use the front axle and rear diff from the 64, never dealt with kingpins before that was some learning curve, spent about 2 weeks heating, beating, pressing, finally just cut thru the bearings, had to do the other axle as I needed a spindle off it, rear was easier but not by much. Then it was the motors turn to bite my ass, had been soaking it as it was stuck, well after a month I pulled the heads and seeing that there was no hope yanked out the motor, that’s when I found that the motor and trans had come from an accident victim, the truck showed no signs of a major accident but the block had 3 mountings broken and welded, bell house was broken and one ear broke off trans. Funny thing is we drove that truck home and about the farm 16 years earlier, till the coloumn locked up and nobody could be bothered to fix it.
  11. Wanderlust
    Wanderlust
    45BDE570-E011-4E4E-B675-9665A2E4B5C2.jpeg 53D8F4E5-EAE1-4B8D-8C21-DD64D0896CE7.jpeg
    On the unibody the torque box comes up into the back of the cab with a step that the bed is welded to, major PITA, I put more structure into the cab and welded a flange to the box, the box bed needs to be replaced anyway , don’t know what was hauled in that truck but the bed is beat!
    Frankie47 likes this.
  12. Wanderlust
    Wanderlust
    67FD3A0B-75AD-4611-A9DD-8815102A3D10.jpeg Now I’m on the search for a motor, found a running motor in a grain truck which doesn’t solve my broken bell housing problem. Took that to a machine shop to be welded, then tackled the tranny, here again subtle differences, while the cases where the same just about everything inside was different, still I managed to make one out of the two. Grain truck was a 58 far as I know, block turns out to be 56 272 with 30 thou overbore and a complete hodgepodge of parts, for example 4 different cast rods all same part #, 4 diff types of pushrods, 3 diff style lifters,heads same part # one Cleveland one from São Paulo, and one oddball piston which also had a split pin bushing, 7 of the pistons were split skirt Ariel, which I have never seen before, and the other was typical flat top, must not have been able to get the right bushing so a larger one was slit and pressed in. Even with all this the engine ran, and rather well, compression was 95 to 120, (oddball was 120) forgot to mention most of the top rings were broken, one was completely gone, along with part of the land.
  13. WB69
    WB69
    Spent many fun filled Friday and Saturday nights cruising with a friend in one of these. He owned it all 4 years of High School without a single repair having to be done to it. Hard to believe because he put it through hell and back.
  14. LM14
    LM14
    from Iowa
    Great job on the metal replacement. Coming along great!
    Been working on mine for several years. Have a big window section for the back of the cab to put in, made a tailgate, added an Industrial Chassis IFS kit, using a modified adjustable QA1 coilover setup in front, created a mirror image inner fender so the right and left sides matched, a Copperstate Components reverse tilt hood kit, swapped in a 390/C6 and have a 4 bar setup with more adjustable QA1 coilovers for the rear......need to get back on it or sell it. They are great little trucks. Lots of ways you can go with one.
    SPark
    DSCN0214.JPG DSCN0812.JPG 4 bar 4.jpg 00m0m_juHmhDcSvaH_600x450.jpg IMG_3105.JPG DSCN0506.JPG DSCN0668.JPG 100_4513.JPG
  15. Wanderlust
    Wanderlust
    76D8511A-CBF0-4940-880A-8BF9DCE4DE9D.jpeg 38CBB8B8-3012-46AA-8C7D-2CA1B764BF08.jpeg Got ahead of myself a little, I actually installed that motor in my truck before finding out about the guts of it, when I found it I verified that it ran before dragging it home, got it for free but had to take the whole truck, once I had it home I put a better carb on and got it running rather well , as I was running it with some mixed gas in the tank I was unconcerned about the blue tinged exhaust, ran it till it was good and warm then dropped the oil, nothing scary in the pan so I drained the glycol and pulled the motor. Then proceeded to put it in my truck along with the front clip, had everything hooked up and fresh fluids and then I fired it up in the shop, well holy fuck did it smoke, so I’m thinking ok probably just some oil leak down from the valves and some residual mixed fuel should clear up, nope! Only getting worse, open shop door and push it outside thinking perhaps it’ll clear once it warms up, wrong again. Don’t know what secret sauce was in the oil but it didn’t smoke until I changed it. So back into the shop, popped the heads off and began learn about all the fun stuff inside.
  16. Wanderlust
    Wanderlust
    Wow nice truck LM14, been keeping mine as close to stock as possible till I get ins/ reg on it then who knows
  17. Wanderlust
    Wanderlust
    1A98CD10-9269-4C0A-A4EF-253464FAB10D.jpeg 26A9D78D-B54A-475A-A6E5-D89F09ABA137.jpeg I now have a rebuilt motor, using the 272 block (had to have the deck stitched due to head gasket installed backwards) punched out to 292, used the crank, rods,and valve train parts from the stuck doaner motor. The heads on the 272 were practically new (small valve truck but oh well), did come across a pair of ECZ-C heads but they needed a complete rebuild, well outside my budget. I’m more of a Chevy guy, this is my first complete rebuild of a Ford engine, apart from a couple top ends on inline 4s , fairly familiar with y block now as I have had this one together and apart several times, instructions are for losers and admitting defeat, right! Right?
  18. Wanderlust
    Wanderlust
    It’s official, insured and plated. Too bad it’s efn winter , -16c still took it for a little ride after the inspection. Bloody cold, would need a winter front.
    williebill likes this.
  19. Wanderlust
    Wanderlust
    AE627D3B-45F7-4CAD-B6F2-94D349B397BD.jpeg Had some good weather today, -1c so I took the truck out for a spin, put on 50 miles. All back roads to avoid all the calcium slop on the pavement
  20. rusty rocket
    rusty rocket
    Those sure are kool trucks, there is a nice solid one for sale in my neck of the woods but they want 9000.00 for it! I don't know what they are going for but 9K seems way to much!
