I built a 1960 Falcon with a Speedway straight axle kit. The front leaf springs are way to stiff and I would like to remove one or two leaves to soften the ride. When I bounce the front the only movement is in the tires. Anybody know which one/s to remove. Thanks
You need stiff springs to absorb the *bang* when you pull the front end 2 feet in the air and the weight of a blown big block comes down hard.
I only got a small block Chevy in it but I still hope to yank 'em up some. I figured a little stiff was good but I'm sure its quite a bit too stiff now.
