'60 Falcon with a sbc need speedo cable info.
Discussion in 'The Hokey Ass Message Board' started by dirttoo, Nov 12, 2013.
  1. dirttoo
    dirttoo
    I am building a 1960 Falcon with a small block chevy and a 4 speed out of a 1979 Trans Am. I would like to use the stock speedometer. I do not have a cable for the Ford dash or for the T/A trans. Is there an adapter to use either cable or is one needed? What cable should I try? Thanks
  2. what does the falcon speedometer use for threads?
  3. dirttoo
    dirttoo
    A 5/8 fine nut screws on nicely.
  4. take a look at pioneer # CA3002 for a 63" cable or CA3004 for a 83"
    i bet they will work
  5. You can go to Napa with the cable Ends & they can get you one
    Check to see if your Cable will bolt up to the Trans
    I know when I did Mine that the Head on the Speed is the Same Thread as the GM
    is
    that was on my 50Merc with the 63 Powerglide
    Just my 3.5 cents
  6. gimpyshotrods
    gimpyshotrods
    Any regular GM cable, of the appropriate length. It is 5/8" on the Falcon speedometer end, and 7/8" on the GM trans. I have a S10 T5 in my '60 Falcon.
  7. 1971BB427
    1971BB427
    from Oregon
    A 1959 Chev cable works well! You didn't mention which 4 speed, but the Super T10 behind the BBC in my '63 Falcon has a passenger side speedo port, so I needed a long cable. The '59 Chevy cable is the longest I could find, and was about $13 at O'Reillys.
  8. gimpyshotrods
    gimpyshotrods
    Before you button it all up, make a note of the color and tooth count of both the drive and driven speedometer gears. You will need to calibrate via changing these gears, so you will need to know what you started with, to you can correct, via the maths.
  9. jeremyhale4311
    jeremyhale4311
    from Georgia
    check with modern drive line
  10. I'm just cheap. Possibly frugal, but mostly just cheap (or broke).
    Take your Falcon cable - will it reach the GM trans?? Yes, good.
    Find a GM cable the fits your trans, length unimportant.
    Now, unscrew the Ford trans end from the cable.
    Unscrew the GM trans end from It's cable. Place onto a punch, and lightly hammer it smooth, so it will fit over the Ford cable.
    Fit it over the Ford cable. Using whatever you have (I use a dimpler), tighten it to the Ford cable.
    Install it.
    Done. Have a beer on me for the money/trouble/hassle you saved yourself.
    Cosmo
  11. gimpyshotrods
    gimpyshotrods
    Except if he finds a GM cable, of the correct length, he can just install it.
  12. bob cutler
    bob cutler
    That ca3002 is 63 inchs long and ca3004 is 83 inchs long both will work autozone had one is stock for $10 that I used.
  13. Mr48chev
    Yep and the speedometer cable catalog is full of "universal cables" with the correct ends on them already made up the right length for beer change. This isn't one of those "has to be custom made" types of cables.
    I think I read where he said he didn't have "any" cable at the moment anyhow.
  14. fordor41
    fordor41
    Or cut the Ford cable ass'y & the GM cable ass'y and sleeve them together. Bought a parts store cable ,cut to length. Did mine 15yrs ago and still operating
  15. gimpyshotrods
    gimpyshotrods
    Why?
    His setup will accept a regular GM cable. No other work need be done.
    His speedometer is 5/8" threaded, and the transmission end is 7/8" threaded.
    This is an off-the-shelf GM cable. Just figure out the length, and buy.
    You guys are over-thinking this.
  16. dirttoo
    dirttoo
    I did think this would have to be custom made. Thanks to you guys I will now go to Autozone and just pick one up.
    Thanks to all!
