6 volt to 12 volt stereo - converter, issues?
Discussion in 'The Hokey Ass Message Board' started by Vorhese, Jan 22, 2009.
  1. Vorhese
    Vorhese
    I've been wanting tuneage in my car for a while but I keep it on 6 volt. I'm thinking about getting one of these converters to run a stereo, amp, speakers, all that. Anyone do this, run into any issues? Wiring problems, generator load?
    CONVERTERS:
    http://www.pressenter.com/~cmeyer/
  2. fishslayer82
    fishslayer82
    I bought an upconverter for my 6 volt car. It was a snap to install, one wire. Works good and does not draw at all. Everything was simple and straight forward.
  3. Vorhese
    Vorhese
    Great, thank you!
  4. Squablow
    Squablow
    My question would be, do you have to isolate everything when using a positive ground system? I've got a converter like this but I can't use it on my positive ground Mopar without insulating every component from the body due to the ground, big hassle.
    Another HAMBer suggested I could add a headphone jack to my stock radio and I could plug an MP3 player into it, that's what I want to do, less messing around that way.
  5. d2_willys
    d2_willys
    from Kansas
    Unless you get a converter that will take 6V pos ground and convert to 12V neg ground you will have to isolate everything from the car and radio grounds. Most people forget all about the antenna being grounded too.
    Check back with me (PM me) in a few weeks and I will have one ready to sell.
  6. Vorhese
    Vorhese
    The converters I linked in my first post do 6V + and 6V - ground. I would probably just wire it straight to just an ipod input and amp. My antennae is just for show anyway.
  7. LeighP
    LeighP
    Yeah, used one on my 54 Chevy years ago to run the stereo.....easy to fit and never had a problem.
  8. bigec
    bigec
    you can put a 12v radio in a 6v car? where do you find the convertor?
  9. Vorhese
    Vorhese
  10. My dad put a 12 volt battery in a battery box behind the spare in the trunk years ago, just for the radio. an occasional charge always worked fine for him. I now question/ worry about that grounding issue... well, so far so good.
    Dad also said back in the old days, guys would run alternators off of the driveshaft. sounds crazy to me....
  11. JAWS
    JAWS
    A separate "stand alone" 12 volt system for your car with a second alternator/or generator and battery would be a possibility, even engine driven alternator as long as the polarity is the same, you could use the vehicle as a ground. The car would then be just a host.
    For your stereo it will work fine, but they are mostly only rated for no more than 10 amps. Stereo and speakers yes, amp nope, unless you buy one of those expensive ones that will handle the amp load you are desiring to run your stereo's amplifier.
  12. bloodyjack
    bloodyjack
    You are not goinhg to get a convertor that will run amps and other such high current devices
  13. Vorhese
    Vorhese
    " · Input Voltage: 4 to 8 Volts DC
    · Output Voltage: 13.5 Volts DC
    · Output Current 6 Amps"
    How many output voltage/amps is needed to run a decent amp?
  14. If you want "THUMP" you will need 40+ amps for the amp alone. If you just want loud you'll still need at least 10 amps of current.
  15. Vorhese
    Vorhese
  16. d2_willys
    d2_willys
    from Kansas
    The converter price is a total rip-off! If you bought one you got ripped, big time! LMAO!
  17. gearhead1952
    gearhead1952
    from Arvada, CO
    Did you know that you can run a 6v positive ground radio in reverse? If your radio still has a mechanical vibrator and not a solid state one then polarity won't be a problem. Tubes don't care but solid state electronics do care. I ran the 6v radio from my 52 f1 in reverse and no problems.
    Can convert car to 12v neg ground then get a voltage reducer to run the radio. Can also get solid state vibrators that are the opposite polarity than what you have now. No need to mess with isolating the grounds.
    Of course the radio can be converted to 12v as well.
  18. Engine-Ear
    Engine-Ear
    Alliance Vendor
    Vorhese, a PM with a solution is on its way.
  19. 6to12volt
    6to12volt
    from Wisconsin
    I am an electrical engineer and designed the unit mentioned in the first post.
    This design has been in production for over 5 years. I have a ISO 9000 contract manufacture build them for me. With over 400 units sold, I have had only one return, and the problem with that unit has not been determined yet. (it works on the tech bench)
    Converters are great for people that want to add a radio, LED lights, GPS or cell phone charger to their 6 Volt vehicle. When you go over the 100 Watt load range, it makes more sense to convert the vehicle to 12 Volts.
    60 to 80 Watt radios are loud enough for most of us. The Positive Ground unit has a maximum current draw of 6 Amps or 72 Watts, the Negative Ground unit has a maximum current draw of 8 Amps or 96 Watts.
    With a Positive Ground vehicle and Positive Ground converter, you do NOT have to isolate the radio, antenna or speakers. I have many happy customers with Positive Ground vehicles and a Negative Ground radio working just fine.
    Send me an e-mail if you have any questions. cmeyer@pressenter.com
  20. Patrick Beasley
    Patrick Beasley
    Looking to ad a 12volt radio to my car, what converter do I need...are what do you recommend..
  21. squirrel
    hi, welcome to the HAMB...look at the dates on posts, before you reply to them. If you look at the profile of the author of the post you are replying to, you can see the little tidbit
    6to12volt was last seen:
    Mar 21, 2009
    so it's really unlikely you'll get an answer from him.
    41 GMC K-18 likes this.
