Hi, I’m looking for a cam to convert a french flat to a 59 ab style. I’m running stock valves and springs, stock 59a intake and single carb. Don’t want to make a race car. What’s the best candidate ? Even a stock one if somebody have it for sale. Also, I’ll put exhaust manifold instead of headers. I need to change the left hand one to clear the steering box. I have a stock 1932 Ford chassis, highboy steel roadster. Thanks.
I haven't physically worked on a flathead in over 50 years and have seen the French version only in pics. But at least I can bump your post back to the top
the 49 to 53 merc is the best "stock" cam, but you still have to cut the gear off as i showed in the other post. easiest exhaust is the 32-36 style with the outlet at the front. lots of clearance for steering
