Hello I just recently picked up a 57 Ford Custom 300 and have started working towards building it into a gasser. I’m ready to buy a front axle kit and have done a lot of reading but have a few more questions. I would like to do a drop axle to keep the front end down. Looks like speedway only offers the 4” drop axle in a 48” width and Im thinking I need a 50” at least. I’m also keeping an eye out for a F1. Also trying to decide on front wheel and tire setup. I thought I decided on the torque thrust originals but realized they are 5” wide and feel like it may be to wide for what I’m wanting. Anyone have any pics? Would pair with a coker f560 165/15 or 155/55. Thanks! Sent from my iPhone using The H.A.M.B. mobile app
Whatever you do, don't use those gawd-awful bolt-on ten spokes that rocket sells. And there's a member here (I can't recall his name... ) who can build you a axle to your spec.
You need to talk to Bill of WAC Custom Axles, he is a fellow HAMB'r also. Here is a link to his HAMB page: BCCHOPIT | The H.A.M.B. (jalopyjournal.com) Here is a link to his website: WAC Customs You don't want a weak,flimsey imported axle under your Hot Rod, so be sure to talk to Bill of WAC Custom Axles. American made !
A 50's F1 axle will fit right in. You can drill them to give you the cool look. I lucked up and got one from a 53 Ford p.u. that already had disc brakes. The guy was installing a Mustang 2 front end and gave me the old axle and mono leaf spring setup. These American wheels are available in 15x4.
Thanks, I think I found a F1 front end going to check it out soon. Are those the d series wheel? I saw those offered in a 15x4.5 but not the originals Sent from my iPhone using The H.A.M.B. mobile app
Anybody else running a 15x5 wheel? Also what tire do you have with it? Pics please! Sent from my iPhone using The H.A.M.B. mobile app
That's even the same color as my 65 Caliente! I have two axles, one from a 56 pickup, which should be the 3" wider version like your 53, and a narrower 50 that already has disc brakes etc., all new springs etc., thinking the 50 might do the trick, but have both options. Also just picked up a pre-welded Alston back half frame for 4-link, have the 4-link and a Mark Williams 40-spline rearend with spool and wheels/tires, should be interesting
Decades back I had a 57 altered that had been built in the 60s. I was told it was an econoline axle, but never worried about it's pedigree since it worked. It also had the rear moved up and the wheelbase was 1" different side-to-side (Garlits stagger, I assumed, it was nicely built). Research the steering connection carefully. Hanging a pair of springs, axle and brake lines is easy. Hooking up a safe steering combo without welding the forged components should be designed in first.
There is a lot of ways to go. I used a 1956 F100 axle with some Speedway parts like the springs and mounting kit. The gear box that is recessed into the frame is also from the F100. The stub on the gear box is Mustang II and the column is a bit custom but worked great. It all worked great for the track but was not fun to drive on the street. Very hard steering unless I was moving. Great candidate for electric power steering. The front tires did not stick out and the Protracs are a bit wider than the ones you looking to use.
