Featured Customs 57 FORD GASSER BUILD
Discussion in 'The Hokey Ass Message Board' started by Lee Veinotte, Feb 6, 2019.
  1. derbydad276
    derbydad276
  2. Lee Veinotte
    Lee Veinotte
    One small update. Axle will be here Tuesday so I wanted to get the front wheels and tires so I can locate everything for clearance. So here are my front runners. 15x5 American Racing and 26x7.50-15 M/T Sportsman Pros. Nothing special but they'll look right at home on the car. 20190214_153121.jpg
    mgtstumpy, Deuces, Oldioron and 8 others like this.
  3. Lee Veinotte
    Lee Veinotte
    That's what I thought too. Plus they're in the states and wow. The dollar and the shipping would kill me. I'd have 2 grand in floor plans! Lol
  4. As a gasser these cars look better without the front bumper.
    It would be a shame to mess with the Niagra front end.
    Really unique.
    Great project.
    The 429 is a great choice.
    Welcome to the HAMB.
  5. Lee Veinotte
    Lee Veinotte
    Thanks! Glad to be here. Definitely going to leave the grill alone, like you said very unique. Its been painted white and the chrome is cooked underneath so it may get a very light silver paint. The bumpers are ok but I'd do them in the same treatment. I think i'll do away with the panel between the grill and bumper and tuck the bumper in tighter to the fender. May have to section and shorten it make it work.
  6. Like your choice of wheels for sure. My 57 runs first gen Torque Thrust, same basic wheels.
  7. 6sally6
    6sally6
    That green one really "speaks-to-me"! Straight axle but...not so nose high. 'Specially like that SOHC engine.
    6sally6
  8. 6sally6
    6sally6
    Gravel pan.
    6sally6
  9. Lee Veinotte
    Lee Veinotte
    That's the one.
  10. 6sally6
    6sally6
    11.5:1 is pretty hefty compression for todays pissy gas but...there is hope!
    On the tear down you could smooth and polish the chambers....maybe unshroud the valves by opening the bores just a tad.....both of which remove metal and lower compression.
    Big overlap cam (tight LSA like 108*-110*) will give it a killer/gasser idle AND bleed off some compression at lower RPM's where detonation can hurt you.
    Block the heat risers in the intake...plenty big radiator with lower thermostat ...keep it cool to avoid detonation/pinging.
    PLENTY of ignition timing...may need a "hot-start button" for cranking when hot.
    Give the heat plenty of place to escape under the hood. Some type of cool-air induction.
    Lotsa places to keep one cool and make it live on pump gas.
    Aluminum heads and you would be golden!!
    6sally6
    31hotrodguy likes this.
  11. RmK57
    RmK57
    If those are the old style trw flat tops with the single valve relief and a 90cc combustion chamber your compression shouldn't be anymore than 10.5 to 1, if that.
  12. King ford
    King ford
    from 08302
    Isn't this ethanol blend shit supposed to take quite a bit of compression?..I've seen claims of making in excess of 700 horsepower on E85 ( 15% ethanol)
  13. Lee Veinotte
    Lee Veinotte
    I've got to pull a head and see what i've got for a piston. The motor was built 25 years ago and never started so I'd say they probably are the pistons you're referring to. Which is hopeful.
    loudbang and 31hotrodguy like this.
  14. AmishMike
    AmishMike
    If valves were adjusted & they sat for 25 years you better check spring pressure.
    OahuEli, loudbang and 31hotrodguy like this.
  15. Lee Veinotte
    Lee Veinotte
    Good point. Never thought of that
  16. RmK57
    RmK57
    I used one of those online compression ratio calculators.
    4.39 bore
    3.59 stroke
    0 deck
    .041 gasket thickness
    90 cc combustion chamber
    and come up with 9.89 to 1. Good old Chevron 94 would be perfect.
  17. Lee Veinotte
    Lee Veinotte
    So shes gotta have one wild pop up to make anymore than 10:1
    That's good, takes a load off wondering if this thing is gonna run decent on pump premium.
  18. RmK57
    RmK57
    I have an old set of standard bore 429 SCJ pistons in my attic. When I get a chance I'll try and get trw part # as they were the supplier to Ford for those forged pistons.
    The original 429 SCJ I had years ago had 11.3 to 1 , but it also had 73 cc chambers. It wasn't very happy on pump premium.
  19. Lee Veinotte
    Lee Veinotte
    That would be great! I'm going to get my front end/suspension/motor mounts and engine position mocked up before I tear the motor down to find out what i'm working with. Got my Speedway kit last night. The quality of everything looks great.
  20. deathrowdave
    deathrowdave
    from NKy
    Mine would laugh at anything but BlueGas , AV Gasoline . Luckily I had a friend that was on the tanker , samples were saved in 5 gallon cans and when pump repairs were needed , excess straight into the Torino Cobra tank . When it was right you would understand the meaning of the title Super Cobra Jet .
    OahuEli, Gammz and loudbang like this.
  21. The stock-ish 429 we ran in the stock car had domed pistons, no idea what the CR was but it made great low-end power off the corners. Looked up the CR, 10.9:1, small wonder it liked AV gas....
  22. Lee Veinotte
    Lee Veinotte
    Well didn't really get much done with the car this weekend but I did do some shop chores. Built a cart for my new mig, cleaned up, hooked up my little compressor. Very productive weekend getting everything ready to do some work on the car. 20190217_160707.jpg
  23. Lee Veinotte
    Lee Veinotte
    Been making small progresses. Rear end out tonight. All the old lines are removed from the car. Got the very difficult to remove steering box/column out. What a poor design for removing the box. 20190222_203102.jpg 20190222_203037.jpg
    mgtstumpy, loudbang and 1947knuck like this.
  24. Difficult to remove the steering box? You must have removed it through the inside instead of dropping it down and out.
  25. Lee Veinotte
    Lee Veinotte
    I did yes. I'll be using a 525 Vega style box so I wasn't too worried about keeping the old one intact. It was very loose anyhow and at its max adjustment. Ended up pulling it apart and removing it that way.
  26. benchseat4speed
    benchseat4speed
    from Golden, CO
    Good call on the front wheels you can’t go wrong with straight spoke torq thrusts. I’m Chevrolet til I croak but you got a neat car and some great plans for it. Big block and three pedals in a 57 Ford body gonna be a cool ride.
  27. I could have helped ya out a bit with info but didn't know you were ready to pull the steering box yet.
  28. deathrowdave
    deathrowdave
    from NKy
    The motorcycle jack is your best friend when doing axle work .
  29. OahuEli
    OahuEli
    from Hawaii
    Did Hotroddonnie own that car at some point? Looks real familiar.
