Projects 57 Chevrolet
Discussion in 'The Hokey Ass Message Board' started by salazarich, Apr 11, 2015.
  1. salazarich
    salazarich
    I am putting together a 1957 chevy two door and suggestions. I am using a 283 I need internals of he engine and interior. Any suggestions on brakes and interior ImageUploadedByH.A.M.B.1428777130.696858.jpg ImageUploadedByH.A.M.B.1428777145.848159.jpg ImageUploadedByH.A.M.B.1428777214.357626.jpg ImageUploadedByH.A.M.B.1428777245.361811.jpg
  2. cdoh
    cdoh
    from chicago
    i see a lot of beauty is the last picture
    Model T1 likes this.
  3. 1934coupe
    1934coupe
    That's a pretty open ended question, I mean how much money do you want to spend? How much of the 283 do you have? Is it a 57 283 or a later model. I'm sure you will wind up with a thousand suggestions from blown hemi to wilwood disk brakes. If you want to sjust driove it and enjoy it, depending on how much of the 283 you have , I would say put that back together, rebuild the stock brakes and suspension, look for an interior guy or try it yourself. There are many ways to go. It just takes money.
    Pat
  4. DDDenny
    283 ,4 speed, 4.11's
  5. Tony
    Tony
    Yep...
    A manual front disc brake upgrade is a nice welcome on most cars with similar size and weight.
    I say that from experience. I have a 57 with a 355 4 speed and 4:10's and although it got rolling real nice the stab and pray 4 wheel drums kinda sucked. It now has manual front disc's and dual master. Stops real good now. :)
    if you dont want disc's i'd at least suggest a dual master cylinder...
    In fact, i'd highly suggest a dual master regardless of the rest of the brake system (providing it was all new)
    As far as interior, hard to beat the bare bones 150 interior, or if you want something more custom but still extremely traditional, simple black rolls and pleats work quite nice.
    Thats all i did.
    Tony
  6. redo32
    redo32
    Your going to need a lot of money for that '57. Sell me that roadster so you can concentrate on the Chevy.
  7. DDDenny
    I saw it first!!!!!!
  8. salazarich
    salazarich
    Thanks redo32 but no
  9. JOECOOL
    JOECOOL
    I wish you were closer, I have a good running 283 and powerslide in my 57 thats coming out,needs a good home.
  10. Fogger
    Fogger
    I bought a manual disc brake kit from Mike Garcia on ebay. mgchevyparts.com Very reasonable price and with the 2" drop spindles went together very easily. It's a misconception that a dual master cylinder is safer than a single chamber. It's only safer if you add the combo/shuttle valve. Without it if you lose a hose or hardline you'll get a couple of pumps and then no brakes. I had it happen to me for the non believers. The whole system must be coordinated to insure safety. Re: interior, Ciadella's is the go to company for tri-5 Chevy's if you want a stock or custom interior.
  11. 56sedandelivery
    56sedandelivery
    Well now, if you step up to a 327, I have all kinds of NEW parts available (pistons in cast, hyperutectic cast, forged, cast crank in large journal, aftermarket rods, intake and exhaust manifolds, heads, headers). It's going to cost MORE to do a 283 than say a 350. I am Butch/56sedandelivery.
  12. Disc up front dual manual master. Stock 210 style interior. Now I'll let you pick the engine. Leave it stock height with new front and 5 leaf rear springs.
  13. salazarich
    salazarich
    I like the suggestions
  14. salazarich
    salazarich
    I have a 283 1957 block but needs work I am looking for a 1957 block with no issues, let me know about the engine joe cool
  15. Stovebolt
    Stovebolt
    Update the front brakes, and go the 4.11 route - you won't be sorry. Maybe a 350ho 327 grid on the cam, 2x4's intake, and a pair of CalCustom valve covers for that 60's look.
    Then you can sell the drum brake setup and 3's ratio pumpkin to me ;)
  16. wheeldog57
    wheeldog57
    YEEEHAAAAAA!!!!!!!!!! that is what I say everytime I drive my 57. 327 L79 motor, muncie m20, 3.70 posi. stock suspension with power disc brakes on front, dual master and proportioning valve. Bias ply skinnys on front and hurst cheaters on back. WOOOOOO!!!! I'M GOIN OUT RIGHT NOW. Been a long winter. Any questions, feel free to ask, I did every nut, bolt, wire, clamp, panel, etc on that car
  17. salazarich
    salazarich
    I am gonna use a Richmond five speed, need a disc brake set up and I have a 10 bolt rear, the 283 will have about 420 horse and planning on a hill born injection we will see the rear end gears can be in the 3's with a Richmond. I do not have an l79 I wish I did.
  18. salazarich
    salazarich
  19. salazarich
    salazarich
    Here is my transmission and original bell housing to mount in the original trans mounts
  20. salazarich
    salazarich
    I am got a high lift cam higher than the 350 ho 327
  21. JOECOOL
    JOECOOL
    Mine is a 82k mile 283 two barrell,powerglide. It runs good ,I put new rear main ,pan gasket ,front cover and seal ,valve cover gaskets and aluminum covers. I'll sell it with manifolds,radiator,air cleaner just like it comes out.
  22. chopt31
    chopt31
    I wanna know how you get 420 hp out of a 283
  23. salazarich
    salazarich
    I speak English everyone knows what I am saying. I am building the best 1957 chevy if you can help fine if you want to mouth off please don't post.
  24. I probably couldn't have been much help anyway.
  25. Fogger
    Fogger
    For specific help with your '57 check out the Tri-5 forum, they have many members who will guide you on your project.
  26. I got nothin'.
  27. nwbhotrod
    nwbhotrod
    from wash state
    so do i
