Projects '57 Cadillac Build - "Emily Jo"
Discussion in 'Traditional Customs' started by JohnnyDeuce, Dec 19, 2014.
  1. JohnnyDeuce
    JohnnyDeuce
    from USA
    Tried to upload more photos, but I was unsuccessful - I'll try again on Monday
  2. cmarcus
    cmarcus
    Looking great! Love the color option...
  3. JohnnyDeuce
    JohnnyDeuce
    from USA
    OK - Haven't posted here in a while, because I've been busy with class and work on the Caddy
    I shifted over from the Body Fabrication class to the Chassis Fabrication class, because there's more to learn in the new one. My welding skills started out pretty bad, but improved over time. So far, I've been able to do the following with her:
    1. Got the gas tank repaired and POR-15'd
    2. Pulled the front fenders, disassembled them and sent them to the sandblaster/powdercoater
    3. Disassembled the front bumper and sent it to the sandblaster
    4. Removed the full interior and began to refinish the floors with POR-15
    5. Disassembled the rear bumper and began the process of repairing the damage to it. Once that's done, the rear bumper will go to the sandblaster/powdercoater
    6. Refinished the trunk with POR-15 and Duplicolor DM100 Grey and White Spatter paint
    7. Began refinishing the remaining original underhood items with POR-15
    I now have one calendar month left of class. In that time, my plan is to complete the following:
    1. Build and mount custom tube grill
    2. Build and mount custom insets for the rear bumper ends
    3. Rebuild the original hydrovac unit for the brakes
    4. Recover the rear seat
    5. Shave the original mirror and the door handles, install solenoids and poppers for the doors
    6. Repair the front fenders
    7. POR-15 the original wheels, install wide whitewalls and chrome spiders
    8. Paint two lace panels on the roof
    9. Install carpet
    10. POR-15 the entire undercarriage (planning to do it after class is over, when she's drivable and I can get her on a lift)
    Pics to follow - If you want to follow the build on my FB page, send me a PM with your FB name and I'll send you a friend request.
    Wish me luck with the massive list of what I have left!!!
  4. JohnnyDeuce
    JohnnyDeuce
    from USA
    Here's some shots from the Body Fab class, showing the damage to the passenger rear bumper end 0629151658.jpg 0630150927a.jpg 0630150927b.jpg 0630150927c.jpg 0630150927e.jpg 0630150927f.jpg 0630151033b.jpg 0630151033d.jpg 0630151034a.jpg 0630151126.jpg
  5. JohnnyDeuce
    JohnnyDeuce
    from USA
    Photos of additional body damage - The gouge in the driver's side front fender was filled with caulk!!! 0630150928.jpg 0630150928a.jpg 0630150928b.jpg 0630150928c.jpg 0630150929.jpg 0630150929b.jpg 0630150929d.jpg 0630150929e.jpg 0630150930.jpg 0630150930b.jpg 0630150930c.jpg
  6. JohnnyDeuce
    JohnnyDeuce
    from USA
    New tool cart and learning how to MIG weld sheet metal
    0701151148a.jpg 0701151148b.jpg 0701151148c.jpg 0701151148d.jpg 0701151149.jpg 0707151102.jpg 0707151102c.jpg 0707151107a.jpg 0707151107b.jpg 0707151107e.jpg 0707151108c.jpg 0707151108f.jpg 0707151108h.jpg 0707151108j.jpg 0707151108n.jpg 0707151109a.jpg 0707151109b.jpg 0707151109c.jpg 0707151109e.jpg 0707151118.jpg 0707151121a.jpg 0707151121c.jpg 0707151123a.jpg 0707151125.jpg 0707151125a.jpg 0707151129a.jpg 0707151130.jpg 0707151134.jpg 0707151134b.jpg 0707151134d.jpg
    jakespeed63 likes this.
  7. JohnnyDeuce
    JohnnyDeuce
    from USA
    More sheet metal MIG welding practice 0707151134e.jpg 0707151137a.jpg 0707151137b.jpg 0707151141.jpg 0707151144.jpg 0707151144b.jpg 0707151159.jpg 0707151159b.jpg 0707151159c.jpg 0707151531.jpg 0707151531a.jpg 0707151531b.jpg 0707151532.jpg 0707151532b.jpg 0707151532c.jpg
  8. JohnnyDeuce
    JohnnyDeuce
    from USA
    More of the initial metal fabrication - MIG welding on the mini-roll pan
    Then we moved on to fabrication of a motorcycle gas tank, which was supposed to be TIG welded - I did ok with the metal shaping, but horrible at the TIG welding - That's when I decided this class wasn't for me and moved over to the Chassis Fabrication class.
    0709151150b.jpg 0709151159.jpg 0709151218.jpg 0709151218b.jpg 0710151124.jpg 0710151124c.jpg 0710151124d.jpg 0710151159a.jpg
  9. JohnnyDeuce
    JohnnyDeuce
    from USA
    Some shots of my instructor welding - His name is Brad and he's both an excellent instructor and a phenomenal fabricator - The class is great, too!
    Other shots are of the '48 Chevy Pickup chassis we currently have in the frame jig 20150719-B-Rad-Welding-09.jpg 20150719-B-Rad-Welding-12.jpg 20150719-B-Rad-Welding-13.jpg 0721151057a.jpg 0721151057b.jpg 0721151100.jpg 0721151100a.jpg 0721151101.jpg 0721151101b.jpg 0721151101e.jpg 0721151101f.jpg 0721151102a.jpg 0721151102c.jpg 0721151102d.jpg 0721151103.jpg 0721151103a.jpg 0721151103d.jpg 0721151103f.jpg 0721151104c.jpg 0721151104d.jpg 0721151105a.jpg
  10. JohnnyDeuce
    JohnnyDeuce
    from USA
    Some more shots of my beginning welding skills
    0721151105d.jpg 0721151105g.jpg 0721151106b.jpg 0721151106d.jpg 0721151644b.jpg 0721151644e.jpg 0727151356.jpg 0727151424b.jpg 0727151601.jpg 0727151602.jpg 0727151619a.jpg 0727151619b.jpg 0727151620a.jpg 0727151620b.jpg 0728151213.jpg 0728151214.jpg 0728151214a.jpg 0728151440.jpg 0728151500d.jpg 0731151321.jpg 0731151321c.jpg 0731151321d.jpg
  11. JohnnyDeuce
    JohnnyDeuce
    from USA
    Shots showing removal of the interior and disassembly of the rear bumper, which I had to use the cutting torch to separate!!!
    0731151321f.jpg 0731151322.jpg 0731151322c.jpg 0731151322f.jpg 0731151322g.jpg 0731151322h.jpg 0731151323a.jpg 0729151805.jpg 0729151805a.jpg 0729151806.jpg 0729151816.jpg 0802151451.jpg 0802151451b.jpg 0802151452a.jpg 0802151452c.jpg 0802151515a.jpg 0802151516c.jpg 0802151545b.jpg 0802151545f.jpg 0802151546.jpg 0802151546b.jpg 0802151546d.jpg 0802151610a.jpg 0802151610b.jpg 0802151754.jpg 0802151756.jpg
  12. JohnnyDeuce
    JohnnyDeuce
    from USA
    Most challenging part of this class and build for me - Repair of the rear bumper ends. The passenger rear bumper end is exceptionally mangled and rotted. Good training!!!
    0810151259.jpg 0810151259b.jpg 0810151259c.jpg 0810151300.jpg 0810151300a.jpg 0810151300c.jpg 0810151300e.jpg 0810151300f.jpg 0810151300g.jpg 0811151328.jpg 0811151328a.jpg 0811151328b.jpg 0811151329a.jpg 0811151329c.jpg 0811151915.jpg 0811151916.jpg 0811151916b.jpg 0811151916e.jpg 0811151916f.jpg 0811151917.jpg 0811151917a.jpg
  13. JohnnyDeuce
    JohnnyDeuce
    from USA
    OK - These are the most recent shots, which show me refinishing the trunk and gas tank. They also show my cool new "Peep Mirrors" and the start of covering the interior floor with POR-15.
    0817151519b.jpg 0817151519c.jpg 0818151018a.jpg 0818151018d.jpg 0818151018e.jpg 0818151302a.jpg 0818151303a.jpg 0818151305a.jpg 0818151306f.jpg 0818151956a.jpg 0818151956d.jpg 0818151957.jpg 0818152035c.jpg 0820151755a.jpg 0820151755c.jpg 0820151942a.jpg 0820151943b.jpg 0820152140.jpg 0820152140b.jpg 0820152140d.jpg 0820152140e.jpg 0820152140f.jpg 0820152141c.jpg 0820152141f.jpg 0820152142.jpg 0820152142b.jpg
  14. JohnnyDeuce
    JohnnyDeuce
    from USA
    That last group of pics also shows one which reinforces why you should wear long sleeves when using POR-15!!!
    One thing I'm really not happy with is the underhood items that I covered with POR-15. Normally, I would sandblast them to get a smoother finish - But lack of time and funding are starting to play a part, now that I only have 1 month of class left to do all my work - Wish me luck knocking it all out!!!
  15. JohnnyDeuce
    JohnnyDeuce
    from USA
    I'm also thinking of replacing the stock tail lights with '59 Caddy lights - Wadda y'all think?!?!? 0730151655a.jpg
  16. 56premiere
    56premiere
    I think you have came a long nicely , and haven't given up on it. You should keep trying tig it is handy to use. And no to the 59 lights. Good luck
  17. JohnnyDeuce
    JohnnyDeuce
    from USA
    More work today on the Caddy ~
    Trying to finish up the interior floor and found a small spot of rusty and broken metal in the under seat area that needs to be cut out and replaced - Which I'm actually happy about, because repairing it will be a good training experience.
    I managed to finish up painting all the underhood pieces and the tank straps with POR-15, which is good. Now I'll be able to start assembling and hanging the gas tank and put the underhood pieces together again.
    Most of the interior floor is now painted with POR-15, except for the area that needs repair and the very front area under the dash.
    Knocking it out a little at a time!!! 0821151347a.jpg 0821151347b.jpg 0821151347c.jpg 0822151628.jpg 0822151628a.jpg 0822151628b.jpg 0822151629e.jpg 0822151653.jpg 0822151653a.jpg 0822151653b.jpg 0822151654.jpg 0822151654a.jpg 0822151654d.jpg 0822151956a.jpg 0822151956b.jpg 0822151956d.jpg 0822151956j.jpg 0822151957a.jpg 0822151957b.jpg 0822151957c.jpg 0822151957d.jpg 0822151957f.jpg
  18. Awesome build coming along nicely
  19. Awesome build coming along nicely
  20. JohnnyDeuce
    JohnnyDeuce
    from USA
    Very happy with metal shaping of the patch piece for my passenger rear bumper end today
    Gotta weld it in now!
    0825151443a.jpg 0825151444.jpg 0825151444a.jpg 0825151447a.jpg 0825151447b.jpg
  21. JohnnyDeuce
    JohnnyDeuce
    from USA
    Some more recent progress, from the past few days - Ground off some rust and paint, took the front fenders to the sandblaster, installed the repaired and repainted fuel tank, fabricated a bracket to push up the emergency brake cable and - repaired the right front fender!!! 0825151804c.jpg 0827151155a.jpg 0827151155b.jpg 0827151155d.jpg 0827151155e.jpg 0827151155f.jpg 0827151155h.jpg 0827151156a.jpg 0827151252.jpg 0827152028.jpg 0827152029.jpg 0828151450.jpg 0828151624.jpg 0828151625.jpg 0828151625b.jpg 0828151653.jpg 0828151654a.jpg 0829151028.jpg 0829151028a.jpg 0829151028b.jpg 0829151039.jpg 0829151039a.jpg 0829151043.jpg 0829151044.jpg 0829151044_HDR.jpg 0829151346.jpg 0829151347.jpg
  22. JohnnyDeuce
    JohnnyDeuce
    from USA
    With just over 3 weeks of class time left, I've had to adjust my expectations and remove unnecessary items from the "To-Do" list ~ With that in mind, here's the updated plan of action:
    1. Repair the front fenders, paint and install the inner and outer fenders
    2. Repair and POR-15 the floor
    3. Install and wire the electric fuel pump
    4. Rebuild the original hydrovac unit for the brakes
    5. Shave the mirror and door handles, install solenoids and poppers for the doors
    6. Build and mount custom insets for the rear bumper ends
    7. Sandblast, powdercoat and re-install the front and rear bumpers
    8. POR-15 the original wheels, install wide whitewalls and chrome spiders
    9. Recover the rear seat and re-install the interior
    WISH ME LUCK!!!
  23. 57JoeFoMoPar
    57JoeFoMoPar
    This project is coming along nicely. Great job with everything, keep it up. We're looking forward to seeing the progress.
    And "no" as well to the '59 lights.
  24. Great metal work on the exhaust tip and fenders!
  25. Slopok
    Slopok
    Those tattoos will be easier to remove than the Por 15.;)
  26. JohnnyDeuce
    JohnnyDeuce
    from USA
    Thanks for all the posts and kind words, guys - I'm really loving how much I've learned while working on this baby... Still a lot of work left to do and not a lot of time left to do it - Wish me luck!
    Latest pics to post:
    Passenger Side Door Handles Shaved
    0903150215a.jpg 0905152103.jpg 0905152104.jpg 0905152147a.jpg 0905152147e.jpg 0905152244c.jpg 0905152246c.jpg 0905152246d.jpg
  27. JohnnyDeuce
    JohnnyDeuce
    from USA
    Right Rear Bumper End Repairs
    0907151134a.jpg 0907151134c.jpg 0907151137.jpg 0907151307.jpg 0907151307b.jpg 0907151308a.jpg 0907151320.jpg 0907151320c.jpg 0907151614a.jpg 0907151614c.jpg 0907151614d.jpg
  28. JohnnyDeuce
    JohnnyDeuce
    from USA
    Right Front Fender Reassembled, POR-15'd and Ready to Install:
  29. JohnnyDeuce
    JohnnyDeuce
    from USA
    Left Front Fender Repaired - Reassembly and POR-15 is next:
    0907151730a.jpg 0907151731c.jpg 0907151830.jpg 0907152058.jpg 0907152058c.jpg 0907152100.jpg 0907152100b.jpg
  30. 57JoeFoMoPar
    57JoeFoMoPar
    More great work man. Keep at it.
    I'll offer one tiny word of advice, which you can either agree with or disagree with. You're obviously very talented and doing a great job, don't forget that your time is worth something, too. When it comes to certain things, sometimes it is more cost effective to just simply replace than to repair. Now obviously since the Cadillac isn't exactly ripe with aftermarket suppliers for most parts, there is a lot of reconditioning required. But, take that bent and rotten bumper corner for instance. If you could have sourced a good, used corner for $50-100, it might have been more cost effective to simply replace than to repair and metal finish the busted one you have. When I redid my car, it took me 2 weeks to hammer certain panels out of flat sheet metal. Now, those same panels are available from EMS for around $200. Makes that decision real easy. Just keep that in mind as your project moves forward; sometimes the cheap way is the expensive way.
    Keep posting progress pics, we're following this
