Customs 57 Buick front springs
Discussion in 'The Hokey Ass Message Board' started by tuffgt, Nov 11, 2017.
  1. tuffgt
    tuffgt
    Hi all from Australia, I've got a 57 Buick Special and I need to replace the front coil springs but I can't get any springs here in Oz. Has anybody fitted any other coils from a different vehicle successfully? Something more readily available. Thanks in advance.
  2. blowby
    blowby
    from Nicasio Ca
  3. 55styleliner
    55styleliner
    I ordered some for a later Impala that are the same OD and length but have a slightly larger wire diameter. They will be a little firmer than stock and I will probably have to trim the length to get the desired ride height.
  4. oldscl
    oldscl
    I got my springs sent from the US from Jamco, and could nominate the drop. No hassles, but not the cheapest option.
  5. mgtstumpy
    mgtstumpy
    Have you inquired if you could get a local spring works to make a set? Given your trade background you would have contacts to source components. I've previously had them made as well as others I know up here.
    Sent from my SM-T355Y using The H.A.M.B. mobile app
