I would like to upgrade my 56 Pontiac Star Chief to disc brakes on the front. If someone has done this and has advice I would appreciate the help! Thanks!
Master Power Brakes did the disc brakes for my 57, turned out great. They take your spindles and machine them to accept tapered roller bearings. Maybe everyone else does that too, they were my only option when I had it done. Here's a link, http://www.mpbrakes.com/products/product-detail.cfm?product_id=703
I'm looking to do the same thing for my 57. Here are some other options for 55-57 Pontiac's - though with the the Performance Online kit you will end up with a different bolt pattern (5 x 4 3/4) on the front than the standard rear (5 x 5). http://www.performanceonline.com/1955-57-Pontiac-Fullsize-Car-Disc-Brake-Conversion-Kit http://www.ebay.com.au/itm/33060633...AX:IT&_trksid=p3984.m1423.l2649#ht_553wt_1344 Bryan, Did you stick with your original master cylinder and pedal setup? BTW, I read your entire build thread a couple of months back. Inspiring stuff! Dan
If you go back you'll see that I eliminated the factory heater box and switch to a aftermarket pedal set-up with a dual resevoir master. You do end up with different bolt patterns. Not a big deal with steelies and caps. I actually found a uni-lug steel wheel for a spare. And you have to run 15's to clear the calipers. Thanks for the nice words on my build. Can't wait to get it out in another month or so. Bryan
Doh! I knew I should have referred back to your thread before I asked. A professional looking job. Thanks
After contact with ABS I will not be goin with them just my gut feeling. Contacting Scarebird again. Pic below is my car since 1983.
So would I. We did a 55 last summer, required a special hub and trimmed rotor coupled with a cheater Metric caliper to fit the stock 15" rim. Customer emailed last week telling me of ABS' setup - supposedly a 80's Caddy caliper (2-1/2" bore) with "secret" 12" rotor. I don't see it fitting, nor the caliper being a good hydraulic match for the stock manual master...
Im sure Sacrebird sells good part. But Check out the guys at performance online . Picked up discbrak kit with booster and master cylindr for my 55 Chieftain.It stops as good as my new truck (non abs stop of course). They are in Fullerton .Ca As to the guys at ABS meet them at our local swap meet nice guys way to overpriced.
To 55Ponchochief, Did you have to lose your 5x5 bolt pattern on the front? Did you have to lose your stock firewall mounted heater core to mount the booster/master cylinder combo? 55Yak
It would seem kind of foolish to me to attempt to run discs with the stock master in the first place. Most disc/drum setups use a dual chamber master made for those applications. But that is kind of a pain in the ass on these, there's not a lot of room to work with unless you move/eliminate the firewall defroster core and put a hanging pedal unit in there.
OK, I guess I am confused. According to Scarebirds website they say no machining is required with their adapter plates and using the parts they list but a lot of you guys are saying machining is required. Also, does anyone know which brake hoses are needed to do the conversion?
I'll find out tomorrow/wednesday. I am just awaiting my front end kit from Kanter and then the new front end will be installed with the Scarebird brackets and disc brake components. Granted, mine is a 57, but the kit is listed as the same.
