56 f100 brakes
Discussion in 'The Hokey Ass Message Board' started by LEFTY_, Jul 15, 2012.
  1. LEFTY_
    LEFTY_
    from The 702
    I am using f100 brakes on my sedan and the grease cups are very in the way is there any one who has gotten rid of the grease cup and used a regular pound in seal instead thanks guys
  2. Baron
    Baron
    Yep. NAPA oil seal (SKF) #15214
  3. LEFTY_
    LEFTY_
    from The 702
    Will I be ok without that cup thanks a ton Baron that was fast
  4. Baron
    Baron
    I have been running that same set up with out the cups for the last 30 years(on a number of cars). The cups were there for the old rawhide seals . Once they started to leak(and the did), the cups kept the grease off the brake shoes. With the new seals you'll be good to go for 100K miles. :)
  5. LEFTY_
    LEFTY_
    from The 702
    Baron thanks again man I searched everywhere I was just going to shoot down to the parts house and ask
  6. el Scotto
    el Scotto
    from Tracy, CA
    Kudos to Baron! :D
  7. Baron
    Baron
    Here are some National Seal numbers that will also work.
    473440, 450461 or 450273.
  8. Fenders
    Fenders
    You don't use a pound in seal "instead," it is used these days whether or not you use the cup.
  9. LEFTY_
    LEFTY_
    from The 702
    i did not know that as long as i dont have to use the cup im golden and baron im assuming these will work on the 42 to 48 spindles
  10. the Napa seal #15214 is for a shaft that is 1.500" in diameter , the part where the seal rides on an old ford spindle is 1.562"......but i'm sure it will work fine
    national 473440 is also for a 1.500" shaft , so is 450461
    i use national # 473441 which is for a 1.562 shaft
  11. LEFTY_
    LEFTY_
    from The 702
    This place is the business thanks a ton guys
