Hey guys, working on the engine out of a 56 Powerwagon at work and I am trying to determine the factory size of the main journals and rod throws and cylinder bore. Engine has a rebuild tag with oversize numbers on it but want to verify before ordering the bearings/rings. This is something I am involved with at work, pretty interesting truck. Started life as a forestry truck and has a supposed "factory" swivel in the frame that lets it articulate between the cab and bed. If original supposed to be one of fourty six made in 56. Thanks!
Okay, found the cylinder bore is 3.25 factory in the manual but it does not seem clear to me what the other specs should be.
Clevite bearing spec book. rods 2.061-2.062 mains 2.499-2.500 rod torque spec 3/8 bolt-45-50 lb. 7/16 bolt 50-75 lb. mains 80-85 lb.
