Hot Rods 56 Chevy 3100 - Ma New "Shop Truck" / Daily Driver
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jun 5, 2019.
  1. 340HilbornDuster
    340HilbornDuster
  2. 340HilbornDuster
    340HilbornDuster
  3. 340HilbornDuster
    340HilbornDuster
  4. 340HilbornDuster
    340HilbornDuster
    Spring Cleaning...
    FO Spray...(found in depths of the Garage)
    from the makers of "Can o' W.A. 20200502_171202.jpeg 20200502_164538.jpeg 20200502_180326.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
  5. 340HilbornDuster
    340HilbornDuster
    swade41, kidcampbell71, enloe and 2 others like this.
  6. 340HilbornDuster
    340HilbornDuster
    Ran great out of the garage.
    Started losing power.
    Noticed the ElCo @ BK's
    Distributor clamp bolt threads gone..
    Distributor Got lose and advanced.
    Tried to restart it. Backfired...!
    Both starter bolts snapped right off and shot the starter right off!
    Hey AAA
    - Yard Work Today! Aloha! 20200508_194730.jpeg 20200508_214525.jpeg 20200509_093311.jpeg
    enloe, swade41 and loudbang like this.
  7. belair
    belair
    Wow- never heard of that!
    kidcampbell71 and loudbang like this.
  8. 340HilbornDuster
    340HilbornDuster
    Me Neither........ (MoPaR) Guy......
    My buddies said there's a 3rd. Bolt that goes in the front of the starter...
    Sent from my SM-G930T using The H.A.M.B. mobile app
  9. primed34
    primed34
    I've never heard a starter getting spit out before either. I hope you didn't crack the block where the starter mounts. There is a bracket that mounts to the block for the front of the starter. I've never used one even with a 11 to 1 compression. I have had starters break mounting bolts, but that was before I learned about using the correct bolt. Laying under a car using an e/z out really sucks.
  10. 340HilbornDuster
    340HilbornDuster
    Yeah i know....yard work today....
    "Easy" out...he he...i'm going in with a "good attitude"...later.
    enloe and loudbang like this.
  11. 340HilbornDuster
    340HilbornDuster
    If...Correction WHEN I get those bolt ends out of there...Driving So far...Kinda LOUD...w 70's..!?
    Got these puppy's.. Old Stock...a ~45 bend and one of these on each side...can't hurt. 20200508_171106.jpeg 20200508_171314.jpeg
    Stogy, loudbang, enloe and 1 other person like this.
  12. I've heard of a starter doing that when an engine was hydro locked, hopefully you don't have any other issues with the timing being that far off.
    loudbang and enloe like this.
  13. 340HilbornDuster
    340HilbornDuster
    The "Magic Tool"...
    Threads out. Starter back in..
    Engine Spins freely...
    Now FIX The Distributor Hold down bolt...B4 Start.m!
    Stogy, enloe, loudbang and 1 other person like this.
  14. primed34
    primed34
    Good for you.
  15. loudbang
    WHEW you lucked out getting them out like that. :)
    Stogy likes this.
  16. 340HilbornDuster
    340HilbornDuster
    I chased all threads with taps B4 i put it in...always do...& i'm lucky!
    Stogy and loudbang like this.
  17. 340HilbornDuster
    340HilbornDuster
    Stogy, swade41 and loudbang like this.
  18. I started a dormant stock car with e BBC one season after a long winter's rest using starting fluid... BOOM... blew the nose cone off the starter, no other damage. Have not used starting fluid since.
  19. 340HilbornDuster
    340HilbornDuster
  20. 340HilbornDuster
    340HilbornDuster
    I've had this thingy for A YEAR!...already...(first post June 5th.)
    WTF! .... Mix of Shock & Denial...
    Finally runs OK...S'More tuning this weekend....
    Time to Haul $#!T & get this back in the Garage...
    I hauled my New TV in the truck today....
    It Took Costco 5 WEEKS! to ship it here...
    I Won't get much work done Today....
    kidcampbell71, Stogy, enloe and 3 others like this.
  21. 340HilbornDuster
    340HilbornDuster
    Kicked my Brother in Law out of the Country - Watch out Sweden! 20200721_211542[35].jpg 20200721_212212[35].jpg
    kidcampbell71, OahuEli, Stogy and 4 others like this.
  22. catdad49
    catdad49
    Wow, I didn't know those old Chevies could float! Love that truck, he could just drop it off in Va. and $ave himself a bunch of money.
  23. 340HilbornDuster
    340HilbornDuster
    #1 done.
    later #2
    Should be "Alot Quieter" w. the Cherry Bombs!? 20200814_125859.jpeg 20200814_194029.jpeg
  24. 340HilbornDuster
    340HilbornDuster
    OahuEli, Stogy, loudbang and 5 others like this.
  25. 340HilbornDuster
    340HilbornDuster
    UPDATE:
    - Replaced the Steps / Rocker panels (Parts - Big Mahalo Walter!!!)
    - Welded up the Butched holes in the center cover plate.
    - Snappy Red Brushed On Paint.
    - Made New side cover plates (front of doors) Still "some rust to fix in these areas!
    - New Power wiring / Disconnect.
    - New $19 carpet from Ross w. frizzle's.
    - A/C Vacuumed and filled -
    - Fixed the 46 Austin Horns.
    Hauling stuff at job site - Got Wood Screw in rear tire. Never fails!
    - Fixed Flat!
    To Do in near future:
    - Hook up power to A/C.
    - Just received New Heater Valve - Replace and hook up control wire.
    - Just received 3 wire Alternator (BBC Starts GREAT when charged correctly)
    Replace and add Ignition + Sensing wire.
    - Getting a used Mallory Distributor with Vacuum advance 4748201 (discontinued)...Tune up and replace.
    Should also make the 454 start better!...And save some Gas!
    - Working on a storage / speaker box behind the seats. Low priority!
    - Received Yellow Seal Beam Head Lights - [Legal in Hawaii] the way I read it!
    Burger King :)
    Later!
  26. 340HilbornDuster
    340HilbornDuster
  27. 340HilbornDuster
    340HilbornDuster
    loudbang and Baumi like this.
  28. 340HilbornDuster
    340HilbornDuster
    A Cold Day at the Beach...(is better than a Hot Day at the Office)
    - Got some ticking lifters cleaned out...(CC 854-16)
    Comp Cams asked me if I soaked them in oil before installing?
    Yes Sir!..."There's your problem it gunks 'em up...We really don't recommend that!"
    Except all Your manuals and spiffy YouTube instructions Recommends to do so!?
    They're still "rattling a little now and then" but it's quieter and across the line!
    And the 854-16 Do Not come a part (only partially)...Parallel bar rivets blocks it.
    - Blinker stopped working.
    It Sucks to trouble shoot the electrical without a wiring diagram!!
    Finally got the Blinker Relay out - STUCK! ripped the connectors out!
    Don't By Hot Rod Wires Stuff
    swade41, Jim Bouchard, enloe and 2 others like this.
  29. 340HilbornDuster
    340HilbornDuster
  30. OahuEli
    OahuEli
    from Hawaii
    Guess I'm missing something, where did the '55 come from?
