Projects 56 buick not charging
Discussion in 'Traditional Hot Rods' started by F&J, Nov 7, 2013.
  1. F&J
    F&J
    No
    disconnect wires at gen, excite the field and test voltage for no more than a few seconds at 1500 or so, rpms
    report back with what you have for volts. analog voltmeter is better than digital for this test, imo
  2. d2_willys
    d2_willys
    from Kansas
    That particular car uses the generator armature terminal to ground the starter relay for the "gas pedal start". You may want to start at the starter relay and verify that the armature terminal is not grounded or wire is fried.
  3. Ok Willys, dumb question where is the started relay located? Thanks Bruce.
  4. d2_willys
    d2_willys
    from Kansas
    On a 56, I believe it is mounted on the left front inside fender well. It is not much bigger than a horn relay, but has 4 terminals.
  5. Ok Thanks I will check it out Thanks and keep you posted.Bruce.
