55 Ford trans swap
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by Blairfootn, Feb 3, 2011.
  1. Blairfootn
    Blairfootn
    I have a 55 Customline 6cly 3 speed manual on floor, Will a ford T-10 bolt up to my bellhouseing? If not do you know of a manual trans 3 or 4 speed that will so I can have a 1st gear syncro.
    Appreciate any help
  2. the other me
    the other me
    welcome to the HAMB
  3. Blairfootn
    Blairfootn
  4. moffetkustoms
    moffetkustoms
    from granby, mo
    welcome from missouri
  5. The T-10 should have the early 49/64 trans narrow mount pattern. The later FORD 3.03 3/S is synchro first and will allow you to retain your column shift. These became available in the 1963 model run.
  6. Welcome to the h.a.m.b.
  7. Total Performance
    Total Performance
    from Nor Cal
    Intros only here man, try your question on the main board. Youll get some good results.....
