55' Chevy "GASSER" Build UP... Yeah, another one
Discussion in 'The Hokey Ass Message Board' started by Chopperman, Apr 10, 2010.
  1. Chopperman
    Chopperman
    Took for a 30 mile trip this morning. Runs good.
    Need to ge the rear in there
  2. Chopperman
    Chopperman
    I'm not reading ANY boost pressure on the guage.
    - Guage works ( tested via blow into line )
    - I was on the freeway the other day, nailed it WOT and nothin:confused:
    - Line is hooked up to intake manifold main plenum
    It underdriven now, but it should still read like 5lbs at WOT loaded.
    Any thoughts?
  3. 55 gasser pickup
    55 gasser pickup
    from utah
    i have never ran a supercharger so idk shit about them except i love the sound of em.we need a video of the car at the track please.
  4. Chopperman
    Chopperman
    I'm working on it.
    Need a new rear end, cage, and some other stuff, before I hit the track
  5. chris55
    chris55
    Sounds great. What size rims and tires are you running in the rear?
  6. GJC
    GJC
    from Santee CA
    Any updates? :D Badass, followed your builds originally on Pirate.
  7. cgaswillys
    cgaswillys
    from New Jersey
    Killer ride. Never too many tri 5 Chevy Gassers. If it were mine I'd radius those rear wheel openings. Just my 2 cents.
  8. Chopperman how's the car coming, what have you been up to with it ??????
  9. whitey70ss
    whitey70ss
    from Central PA
  10. Chopperman
    Chopperman
    I'm getting ready to pull the trigger on some go fast goodies:
    New fuel system
    Holley 750 blower carbs, linkage, fuel lines, and pump
    Currie 9" housing and 31 SP axles
    Currie 9" third and trac lock; on the fence between 3.75 and 4.10 though.
  11. ***Area-51***
    ***Area-51***
    from Ohio
    some nice parts to add to the cause....
  12. fitzee
    fitzee
    Dont you just love go fast goodies!! sweet!!
  13. bnokle
    bnokle
    Anymore updates? I want to see it run.
  14. Chopperman
    Chopperman
    Project is on hold. Trying to buy some property.
  15. TULSA
    TULSA
    from Tulsa
    How about now? Always followed your builds over on Pirate.
  16. Chopperman
    Chopperman
    Got the property (4 acres); still working towards getting my parts list filled ; planning on building my shop possibly this summer, so it may be next year before I can hit the track
    In the meantime, I cut a nice little circle track just big enough for a few karts to run side ny side or one model A to run hot laps!!
  17. ***Area-51***
    ***Area-51***
    from Ohio
    congrats! nice place...
  18. rc.grimes
    rc.grimes
    from Edmond, OK
    Did you find the cause of the no boost reading?
  19. Chopperman
    Chopperman
    bad guage.
  20. Chopperman
    Chopperman
    A few updates - bought the property and have been working on the house pretty much non stop since my last post, hence no posts LOL. Anyway - I'm back on the 55. After driving it a bit, I found that the front single cylinder piston calipers just didn't have enough stopping power. Scary really for discs. So I upgraded to some 4 piston Wilwood calipers and 11" rotors. Honestly, these parts just don't look right on the car, but I'm a big fan of stopping. Scored a new to me 9" 4.11 with a locker, ordered up a 56" 9" housing with currie axles and 11" drums from speedway. New 10" steel wheels, some other odds and ends and electronics (rev limiter, 2 step, and shift light)
    I'm in the process of doing a spring relocation and wheel well widening to allow for larger meats, the 8.20 Firestones just weren't getting the job done.
    Anyway - I'll try to post up as I go.
    kiwijeff, kidcampbell71 and Chucky like this.
  21. Finn Jensen
    Finn Jensen
    That must be your new shop. Neat and spotless!
  22. Chopperman
    Chopperman
    Still haven't got the "shop" built, I just gave my garage an overhaul. That was a project all on it own. Widened garage door, tore up Lino floor and painted concrete, painted, etc.
  23. Nice to see this thread pop back up, I went back about 5 pages getting refreshed on it. Back in 2011 I told you to send me that blower, I'm proud to say I have since built a blown 540 of my own. 20160310_162925.jpg
  24. Rex_A_Lott
    Rex_A_Lott
    Subscribing...a few years late.:)
  25. Chopperman
    Chopperman
    Axles, housing, and rear drums showed up. Got the 1/2" studs pressed in tonight; sometimes the simplest things seem to take the longest time.
    Still contemplating ladder bar lengths.
    Check out the pic of the 31 spline axles next to the stock 55-64' 17 spline axles.
  26. Chopperman
    Chopperman
    Axle / Wheel test fit.
    All is good. Pictures don't show, but I have about 2.5 inches on each side of the wheel. I'm confident that 13" section width street tire will clear with room to spare, a squishy fat slick on the other - we will see.
  27. Chopperman
    Chopperman
    Parts are getting here faster than I can work on it.
    30x10.50x15 Hoosier drag radials. They measure 29" tall, with a 12.5 section width and and 10.5" contact patch ( mounted on 10" wheels at 30psi)
    I needed a tire with minimal sidewalk flex in order to maximize contact patch and not rub. Also wanted to be able to use these tires to drive around town on, but didn't want a DOT approved tire.
    I found these non DOT lightweight drag radials. Pretty interesting concept really. You can run these on the strip at around 20psi and they won't flex and or grow like a traditional bias ply. In researching I've found guys running in the 8's and 9's easily. A lot of guys like em because they run consistent times, they're really sticky and have better overall stability due to being able to run higher pressures.
    Don't confuse these with a cheater skick, these are legit slicks, but in a radial format. It will be interesting running them.
  28. Chopperman
    Chopperman
    Back on it. Inboarded springs 3", all new rear end parts/ suspension, started on inboarding wheel wells.
    I spent almost all day stripping undercoating around weld areas... err..
    [​IMG][​IMG][​IMG][​IMG]
    kiwijeff and loudbang like this.
  29. Chopperman
    Chopperman
    undercoating anyone?
  30. Chopperman
    Chopperman
