I put a 55 dash in my 52 chevy truck. I dont have pics on this but will try and get a few for you later. Tony
Took a couple pics a few minutes ago. Some serious slicing and dicing to make it fit but well worth it as far as im concerned.
Thanks guys. 55/56 dash's are one my favorites and my stock dash was a mess and ugly, so i figured why not try and make one fit. Turned out to be one of my favorite things on the truck. Much appreciated Tony
Thanks Buckeye. It kinda was. I cut the dash into i think 5 pieces, and narrowed it about 5" to get it to fit right. I probably had around 40 hrs of metal work into it when it was finally done. Then i had to make it flat enough for shiny black lol Thanks again guys. Tony
That 55 Chevy car dash looks great. I was gonna do that. Then I changed my mind to use a 57 car dash. Then I changed what was left of my mind and left my 48 Chevy panel dash original. I sure like yours.
Model T1, thanks! Your's looks great too though. I actually like the original ones when they are restored and clean looking. My whole truck was a hacked pile of shit, and they didnt spare the dash in the mix. So it had to come out regardless of what went back in its place. So i figured if i had to do the surgery, i may as well give it a face lift and some botox. Hahaha Tony
That's another reason I didn't use a 57 Chevy dash. Lots of work that I would probably mess up. I kind of like the looks of most old cars. That's why I enjoy owning and seeing them. Had I owned a 47-54 panel or truck years ago I would have changed it to be different. But now diffferent is stock. Altho my gauges are off the shelf Dolpin. I first used some Ford guages I had. Looked nice but I couldn't get the lighting right. This was pre- LED which is not traditional.
Yeah the wrap arounds on the ends were a bit tricky. What made mine worse is my doors are suicide so the jamb area needed to be "finished " as well. Anyway, Not only do they have to line up as close as possible, but there should also be a place for door panels to tuck under in order for them to look good. I have a 1/4" slot all along the lower edge of the door sections so an apholstered door panel will tuck under it and look like it belongs there. It certainly does not have to be that way, a panel could easily be sewn at that edge to butt against the dash, but i just feel it add's a little more quality being able to tuck it under. I know, i over think stuff. Hahaha Thanks again fella's. Flamed48, i say go for it if your up to the tin work. Tony
