Customs 55 Capri ( Mild Custom )
Discussion in 'The Hokey Ass Message Board' started by Austinrod, Mar 7, 2013.
  1. 49ratfink
    49ratfink
    great looking car. love the tuck-n-roll insides. I wouldn't do anything but drive it... OK, maybe drop the back a little , but that's it.
  2. Austinrod
    Austinrod
    from Austin
    More
    .......Sent from Ar
  3. arkiehotrods
    arkiehotrods
    You do know, Austinrod, that you are torturing us with these photos. That car is righteous!
  4. 56premiere
    56premiere
    Very nice, enjoy it. Jack
  5. Caddy-O
    Caddy-O
    You're bringing it to Roundup ...right?
  6. Austinrod
    Austinrod
    from Austin
    I'll try
    .......Sent from Ar
  7. Austinrod
    Austinrod
    from Austin
    1. There was a spray leak from this hose that I need too replace hopefully I can find a replacement or something similar.
    2. plus I need the front brake pedal fixed it seem I use it once and then doesn't work again after that until I put the foot behind the pedal too pull it back and then works again.
    And the carburetor is gummed up and need too be cleaned and regulated.
    3. And maybe switch the car from 6v to 12v.
    4. Plus the tires might need too be replaced
    .......Sent from Ar
  8. Post Apocalyptic Kustoms
    from Outside
    Not to bash your taste, but the bullet caps and the smoothie type wheels will make the car look lame. Stick old school with some type of full hubcaps and you will get a lot more respect.
  9. Austinrod
    Austinrod
    from Austin
    Yeah tried the bullet caps didn't fit the centers so right now ill just run the stock caps on it but I want too definitely lower it
    .......Sent from Ar
  10. Austinrod
    Austinrod
    from Austin
    Thanks for the link
    .......Sent from Ar
  11. Austinrod
    Austinrod
    from Austin
    I'm thinking of adding a set of 53 Cadillac hubcaps too my ride ( haven't found some yet ) and
    air ride for the look
    Posted from Ar
  12. Austinrod
    Austinrod
    from Austin
    Here what they look like on a Watson car
    Posted from Ar
  13. Austinrod
    Austinrod
    from Austin
  14. merc-o-madness
    merc-o-madness
    that car in that color would look cool if it was chopped liked 2-3 inches and remove some trim off it
  15. squeaky32
    squeaky32
    nice looking 55, im running 54 olds caps on mine and look good, maybe check out those or 57 lincoln caps instead of the caddy, the caddy caps might require a deeper rim than what you got.
