Projects 55 buick special brakes
Discussion in 'The Hokey Ass Message Board' started by tcarrasco84, Sep 17, 2012.
  1. tcarrasco84
    tcarrasco84
    can anyone direct me to a master cylinder and pedal assembley aftermarket for my 55 buick special.im looking at one from summit firewall mounted,http://www.summitracing.com/parts/CMB-14-0016/.and will this be adaptable to the drum brakes on the car?
  2. csimonds
    csimonds
    Did you try Mark, Scarebird, here on the hamb? He usually can point you in the proper direction.
    Chuck
    Sent from my DROID device using the TJJ mobile app
  3. blmyachtsales
    blmyachtsales
    from Swansea MA
    That's a single outlet ( i am using the same cylinder for a clutch) consider going to dual cylinders or a dual outlet for safety. Either way their are several different size cylinders. Diameter is the important variable along with pedal ratio. Howe and willwood both make cylinders / pedals. Look to the circle track set ups or make your own.
