*all parts new mostly from danchuck unless noted as used 55-56 Heater Control Valve-$55 55-56 horn relay-$15 55-57 upper radiator hose kit-$13 55-56 shift indicator wire rod-$5 55-56 heater lever control knobs-$7 55-57 shift column lever link bushing-$4 55-57 tailgate rubber bumper wagon-$7 55-57 radiator support fender shim kit-$6 55-57 Steering column to dash pad-$2 55-56 heater assembly fastners deluxe set-$3 55-57 inner fender wire harness clips-$10 55-57 gas/brake line frame set clips-$8 1956 temp sending unit-$18 55-56 dimmer switch-$16 1955 front driver brake junction block-$25 55-57 stop light switch(X2)-$13 55-57 lower door drain seal-$4 55-56 ballast resistor-$20 55-57 brake pedal crossshaft bushing (X2)-$3 55-56 deluxe heater seals-$15 55-57 brake/clutch pad-$4 55-57 window molding clips rear quarter upper and lower-$14 55-57 turn signal pawl kit-$4 55-56 signal cancel cams-$4 55 4 way flasher kit-$$$????$$$ 55-56 chrome ignition bezel-$6 55 wire harness grommet 4-hole - $3 55-56 exhaust manifold bolt locks -$13 57 ignition wires support bracket and grommet-$30 55-57 bell crank bushings -$$$$???? 55-56 volume, selector, windshield wiper-$6each air cleaner & silencer decal-$$$$$$????????? 55-56 front bumper mounting kit-$12 55 park taillamp and body seal-$8 55 battery hold down rubber pads-$4 55-57 rocker panel plug -$4 55-56 bel-air dash script -$11 55-57 sedan side glass setting kit -$18 55-56 2 door paint gasket set -$7 55-57 sedan delivery, wagon rear window seal $18 55 fender anti-squeek gasket set -$11 55 taillamp to body seal (X2) -$8 55 taillamp lens-$9 55-56 hood anti-squeek gasket set - $54 55 hood side bumper-$2 55 kick panels pair -$15 55-57 4 door sedan/wagon sill plate set - $112 55-56 temp gauge (remanufactured)-$75 55-56 firewall bolt set - $17 55 dist cap-$11 1957 "V" rear chrome 150 & 210-$75 1955 heater control (rebuilt)-$60 55-56 clutch pedal return spring -$13 55-57 wiper arm stainless left/right- $18each 55 hood latch support- $$$$$$$??????? 55 heater control levers- $15 55-56 210 horn cap (used) $25 55-56 bel-air horn cap (used) $30 55-57 right and left wiper mechanism -$$$$$?????????? 55-56 kick panel vent seal (X3)-$8 55-57 headlamp to fender bucket seal -$5 55 taillamp lens gasket set )X2) -$3 55 hubcap decals white -$7 55-57 drive shaft yoke fine spline Muncie/th350-$$$$$$$$$$???????? 55-57 lower radiator hose -$13 55-56 steering column floor seal-$10 55-57 upper ball joint (X2) - $18 57 heater control cables -$55 55 front license mounting bracket-$7 55-57 wagon/delivery rear class chanel- $$$$$?????? 55 horn relay (used) -$4 55 turn signal arm (used)-$5 52-66 outside door handle gaskets -$4 55 cigarette lighter assembly -$39 55-57 door hinge to pillar screw set-$4 55 brake line clip set -$4 55-57 rear door hinge screw set (X2)- $9 55-57 tailgate fastner set $20 55 4barrel linkage assemble carb -$60 55 hood bird (used driver quality) -$40 55 hood emblem (used) -$8 55-57 wagner sealed headlights -$5ea 55-57 wiper blades-$18 ea 55-56 4 door wagon rear quarter curved glass left - $175
