Projects 55 210 Wagon Progress
Discussion in 'The Hokey Ass Message Board' started by MP&C, Mar 24, 2013.
  1. Terrible80
    Terrible80
    Bowtie Coupe, MP&C and loudbang like this.
  2. MP&C
    MP&C
    We need to do another spray out test panel, so we can nail down the top color to accent the green. These car bodies just aren't big enough to do a two tone...……..
    ….so we fabricated a fake quarter panel using the Tommasini wheeling machine, and sprayed it with some epoxy primer. We'll get it blocked on Saturday and spray the bottom using Organic Green Kandy Basecoat, and spray the top with Galaxy gray, to see how well those two go together...
    brEad, JUNK ROD, loudbang and 7 others like this.
  3. MP&C
    MP&C
    Now for some color to our paint sprayout sample.. It's too cloudy out today but we're hoping for sunlight tomorrow to better show what this will look like. Until then, Milwaukee Sun...
    Video version:
    D-Russ, brEad, Bowtie Coupe and 6 others like this.
  4. Wow that color really pops! Can't wait to see it in the sun.
  5. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Going to look super sharp Robert. Looking forward to seeing it in color! Larry
    MP&C, lothiandon1940 and loudbang like this.
  6. all the cool kids have green cars..........;)
  7. loudbang
  8. That green is looking great. I used to be a die-hard blue guy, but in recent years I've really come to appreciate the various greens. Can't wait to see this car when completed.
    OLSKOOL57, MP&C, Bowtie Coupe and 2 others like this.
  9. low budget
    low budget
    from Central Ky
    Painted my 4 door 55 a 99 GM green and white 15 years ago, car long gone now 455.jpg
    rtp, jakespeed63, MP&C and 3 others like this.
  10. low budget
    low budget
    from Central Ky
    Not trying to recommend the white, its just what I did, If the client is set on those colors, you still have a few options in my opinion, just using the Green, *Green with top and post silver (< dont think "I" would do that one)
    Green with only posts silver, Green with green posts and only very top silver.
    Might take this over to the photoshop thread to get a general idea of what you might do.
    D-Russ, jakespeed63, MP&C and 2 others like this.
  11. MP&C
    MP&C
  12. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    In the booth pics it looks like green is darker and the top silver . Outside the green seems lighter and the top looks gray. Which way is it suppose to be. Just curious. Larry
    loudbang and rockable like this.
  13. MP&C
    MP&C
    Larry, the top color is Galaxy Gray, the bottom is Organic Green Kandy Basecoat. The gray is darker due to the reflection and the sun being indirect. Inside the booth it was using an LED light aimed directly at the panel.. Here's the gray with a bit more direct sunlight, as it would see on the roof..
  14. MP&C
    MP&C
    Here's a sneak peek at our speaker trim rings just back from DGM Chrome in Philly. Looks like we'll get a couple set up with the stainless mesh so we can show them off at this weekend's car show in Leonardtown..
  15. rockable
    rockable
    loudbang and MP&C like this.
  16. MP&C
    MP&C
    This is back woods engineerin' so don't laugh too hard... I don't have the fancy alignment tool and didn't want to pull the third member, so perhaps this is the next best thing.. My theory is that once you weld the pads repeatedly it should introduce some shrinking along the bottom side which should also cause deflection to both the housing and also the shafts bolted into that housing. I feel this also will deflect the wheels/tires that they will be pulled in at the bottom of the housing, which is the results we noticed.
    With the axle housing fixed on top of jack stands, a bent axle SHAFT would cause run-out as you rotated the tire. So first off, rotate the tires to insure the wheels are straight, to insure the AXLE SHAFTS are straight, to give us a good starting point. Then remove jack stands and set the tires on top of milk crates, open end of the milk crate is facing upward to help keep things from moving... Then the axle housing is rotated around the axle shafts. The shrinking from welding on the pads causes a short side along the bottom, which pulls the wheels inward. This pull follows the bottom (pad) side of the housing as it is rotated around. So the dial indicator shows where these narrow and wide spots are. The heat was applied to the widest spot of runout per each side, and once cooled, re-test and repeat. This is by no means as accurate as the alignment tool, but it's what we had to work with..
    The dial indicator "stand" was a piece of rusty thick wall pipe that didn't move much, so it was moved into place depending on the end we were on and checked for shimmy before proceeding. OK, let the laughter commence..
  17. belair
    belair
    Never laugh at what works. Just have a helper hold your beer.
  18. rockable
    rockable
    Thanks, Robert! I think that is brilliant. I have a couple,I need to check.
  19. MP&C
    MP&C
    Since we got our freshly chromed speaker trim rings back from DGM Chrome in Philly, it only stands to reason that we need to put another sample together for the car show in Leonardtown on Sunday. So today I stopped by Norris Upholstery and picked up a scrap to cover one of the kick panels to make it more presentable. Fake upholstery, if you will..
    We planned on adding a plateau to the stainless speaker mesh rather than flat, so some pressing fixtures had been cut out on a water jet for us..
    Comparing the flat to the plateau....
    installed...
    This might even work.... looks a damn sight better than the plastic grills they come with..
  20. loudbang
    Man you are one ingenious dude. Great thinking on both the axle housing and the bumped speaker cover inserts.
  21. Outstanding! You guys are performing miracles down there, Robert. Loving the "plateau" effect on the speaker grilles. Amazing how a small change can make such a dramatic difference.
  22. MP&C
    MP&C
    Thanks for the comments guys!
    On these grills, to clarify, the smaller (tweeters) use a smaller opening pattern (more holes per inch) than the midrange speaker next to them, so they would appear the same proportionally. McMaster Carr sells a sample kit of the mesh to help in picking out the size, p/n is 9231T11. For the sub we used 5 x 5 mesh (5 openings per inch) p/n 85385T31. For the midrange, 8 x 8 mesh, p/n 85385T42. For the tweeters, 10 x 10 mesh, p/n 85385T48. The grill for the sub will have multiple pressings, one to include a recessed crest emblem. That one will be the test..
  23. Robert, as always your work is impeccable ( I'm running out of adjectives to describe your work ) the newest update on the speaker grilles are beautiful.
    BTW, I thought about you earlier today as I was having a cheeseburger at Arnold's, I sat in the same booth you , John Micheal and I sat last time you were here. HRP
    OLSKOOL57, lothiandon1940 and MP&C like this.
  24. MP&C
    MP&C
    I was just down in SC last week, but closer to the coast in Fairfax.. Will have to swing by again sometime...
  25. The Ford axle housing you have is prone to warping, DAMHIKIJK...
    An easy test for housing straightness is to check to see how the axles go in/out. On a dead-straight housing with clean bearing bores, you can push/pull the axles in or out with your hands, maybe some LIGHT tapping may be needed. If you have to step up to a slide hammer to remove/install, two light-to-medium whacks should be all that's required; it's slightly warped, but still should be OK. If you need heavier/more whacks, the housing is bent enough that axle bearing life will become problematic. If it's bent that much, you'll probably have to have the ends cut off and re-welded with a fixture.
    And if you're planning on a rear sway bar, DO NOT use a bar that attaches to the housing with end links to the chassis; it WILL bend the housing and start eating axle bearings. Use a chassis-mount bar with the end links going to the axle. This is how Ford installed their bars on the leaf-spring cars. Art Morrison straightened my housing three times before we figured that out. That's also why I own a slide hammer...
    You can use a housing-mount rear bar IF you step up to the coil-spring housing as those are considerably beefier. Or use a late (late '60s up) truck housing as Ford did fit housing-mount sway bars to some of those.
  26. Jay71
    Jay71
    The craftsmanship on this thread is mind blowing and hits very very 10388045_701925896532422_984279271_n@.jpg close to home for me! Heres my Green and Pearl White 210 55 for reference.
  27. MP&C
    MP&C
    So last weekend I went to Ron Yeager's shop in Kingsville, MD for a metalshaping workshop. Reconnected with some old friends and made some new ones.. Thanks to Ron for opening his shop so we could all learn some new tricks and methods..
    Today I got another speaker trim ring put together.....this one for the sub in the cargo area of the wagon. We planned on a recessed crest in the stainless mesh, so the mesh was aligned in our aluminum plates and pressed in the Diacro press brake using flattening dies.
    Video Version....
    JUNK ROD, brEad, Bowtie Coupe and 7 others like this.
