54 Merc suspension question
Discussion in 'The Hokey Ass Message Board' started by All_Business, Jun 18, 2013.
  1. All_Business
    All_Business
    Good morning gentlemen!
    I have a noob question to ask. Can you identify what this suspension belongs to? I'm not sure if it is factory 54 Mercury or if it has been front clipped. To me, the front cross member looks as if it is fabricated. However, the rest of it looks like it could be factory. Let me know what you think.
  2. Ralphies54
    Ralphies54
    Wow,I'm no suspension expert but the crossmember, lower A arms, coil spring, swaybar bushings.shock bushings or the absence of them would make me run to the nearest frontend shop for some advice. Those coils have been heated and now the coil wires are in bind as the suspension moves up and down any small amount. Show us some pictures of some of the other "problems" as I'm sure you got them based on these picts.
    Build 'em right and enjoy them for a long time.
  3. 57Custom300
    57Custom300
    from Arizona
    It does look rough! It looks factory to me except for the front crossmember like you mentioned. I know 55 & 56 Ford were very prone to the front crossmember rusting out & yours looks like that's what happened. Replacements are hard & expensive to find so most guys just make one.
  4. kenymac
    kenymac
    As has been said the front coils have been heated up to drop the front end down, Not a good way to go. Looks as if some one repaired a rusted out front crossmember, Which is a real common problem with 54-56 Ford and Mercury cars as they rust out from the inside out. There is an outfit that makes replacements for it. Also I would take out the heated up coils and install Ford Areostar springs as they bolt in and drop the frontend down with a good ride.
  5. RDAH
    RDAH
    from NL, WI
    Looks a lot like mine, but yours has some patch work done on that front cross member.
    Get those f..... up springs out of there & put some Areostar springs in, you'll like them.
  6. That's all 54 Factory stuff. The front crossmember has had some repair done to it. I wouldn't worry about it unless it's appearance bothers you.
    The Wizzard
  7. hoop98
    hoop98
    from Texas
    These guys used to make the front crossmember;
    Goodell Fabrications is a company categorized under Welding Repair.
    Address
    s 69 hwy Coweta, Oklahoma, United States
    Show Map
    Phone Number
    +1 (918) 486-6498
    Definitely try the CC850 springs, yikes!
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    Click on "Your Notifications" it should be flashing and join up, all the help with the Aerostar coil and shock swap and part numbers are there for the asking.The crossmember repair looks OK and is common in 50's Fords & Mercs.Looks like you need sway bar bushings and links,Energy Suspension has replacements for better handling at about the same or less that the Ford specialty suppliers.
  9. All_Business
    All_Business
    Thanks a lot guys. That helps tremendously. I'll get on that group and start putting together a list of parts.
    The Whole car is this rough, but the drivetrain is all fox body mustang and I got the car with a title on a trade for something I couldn't sell anyway. So, Its well worth it.
