54 Ford F100 VIN tag attachment?
Discussion in 'The Hokey Ass Message Board' started by jkane, Apr 9, 2013.
  1. jkane
    jkane
    I looked at a Ford F100 and the VIN tag was on the glove box door and attached with screws. Is this correct? The truck has been "clipped". Are there any stampings located on the frame, other than those that were on the front?
    Thanks
  2. okiedokie
    okiedokie
    from Ok
    Glove box door is correct, with screws.
  3. jkane
    jkane
    Thanks Okiedokie. Always had Chevys and could not believe that the screws were legit. How about a VIN stamp on the frame or body other than the front frame? The front frame is gone due to the addition of the front clip.
  4. 40FordGuy
    40FordGuy
    Some Ford trucks had a VIN stamped on the driver side frame rail, just ahead of firewall, And, on the "pass side" frame rail, above the rear axel "kickup". Ditto, the glove box plate is correct, screws and all.
    4TTRUK
  5. okiedokie
    okiedokie
    from Ok
    I don't believe there are any numbers on the frame. Pretty sure that door jam [where it is on my 53] and glove box door is it.
