54 chevy rear 2 link set up
Discussion in 'The Hokey Ass Message Board' started by draggin54, Nov 11, 2009.
  1. draggin54
    draggin54
    from det. mi.
    heres my 54 chevy 2 link set up what ya think,later
  2. pugs
    pugs
    from Hamburg Pa
    it looks god but i think you mite need some sort of panhard bar to keep the rear centered out on cornering
  3. draggin54
    draggin54
    from det. mi.
    yeah not quite done yet,either a panhard or a watts link not sure yet. right now its completely bolt on except for rear end saddles. thanks
  4. I Drag
    I Drag
    This looks like some sort of kit. Where do you get it?
  5. draggin54
    draggin54
    from det. mi.
    ive been messig around building this myself and who knows maybe people would wantto buy it.ive been tryin to make it as user friendly as possible so if anybody was interested i could build it for um.
  6. draggin54
    draggin54
    from det. mi.
    its sittin right now cause i'm working on my 58 belair right now
  7. I Drag
    I Drag
    What I meant was that the front brackets look like they were made on hydraulic punch presses and press brakes, not handmade. I mean that as a compliment actually.
    I was just asking for another project that I want to eliminate the leaf springs (not the '58). Thanks.
  8. inliner54
    inliner54
    i would use a watts link. its lookin good.
  9. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    I wonder how the rearend will articulate when only one wheel needs to pivot up or down. Most 2 links seem to allow for independent movement by either "twisting" of the truck arm (early 60's chevy trucks) or through heim joints. I would think that if one side travels up, the other side might follow with it. Seems too rigid.
    I hope it works, it seems you've spent some time fabricating. I too have a 2 bar setup in progress on a 51 chevy.
  10. draggin54
    draggin54
    from det. mi.
    i made the 2 link bars rigid with cj7 urethane bushing replacements, but there are rod ends now that have a internal pivot joint ive thought about going 2 just havent been rushing, got a lot of time in my car you know how that go's but not lookin for anything but u and down nice and simple and under the floor, have a family so cant loose the back seat. later
  11. draggin54
    draggin54
    from det. mi.
    probly the way i'm going, thanks for checkin it out. later Mark
  12. Usual issue with rigid mounts at the diff - you need the bars to come to the centre or at least pointing to the front uni on the tailshaft. Otherwise bind, bind, bind and sooner or later, something's got to give.
  13. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    I was just thinking it might be too firm of a ride in the back(for the family), which is why I went with something a little less rigid. Keep us up on the progress. I want to see how you work out the other stuff like springs or bags, shock locations, panhard or watts link.
  14. Da Tinman
    Da Tinman
    It wont articulate. Same principle as split rear wishbones.
    Looks real nice but its not the safest thing in the world.
  15. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    Yeah, I was trying to be subtle, seems like a lot of pretty fabrication, but you know...form follows function.
  16. draggin54
    draggin54
    from det. mi.
    i'll post more in while, gotta get my 58 done first thanks for the comments, later
  17. outlaw1949
    outlaw1949
  18. jfrolka
    jfrolka
    They look like belltech drop hangers for a 88-98 chevy truck.
  19. jfrolka
    jfrolka
    run a track bar.. go from one link bar corner to opposite corner.. Use some 5/8 heims on some 1.25" tube with a set of tabs. 2 links drive really smooth.
