so i recently got this 210 in a trade as is. had no motor or tranny pretty much a shell. the body has is pretty much done,top has been removed i prefer it with a top so i might have to check that out later on. well the other week i dropped in a 350 with a t400 tranny got new wiring running thru the whole car got everything wired up got it started so now im working on the rear end. it has a camaro rear end on it i believe, its what i was told, i put a couple blocks on it got it lower then it was but now i need to get the leaf spring mounts welded on it since the guy i got it from cut them off and then the front. any suggestions on what to do? im a starter so im not so familiar with welding but i am learning. im a mechanic so anything with the engine i got on lock. the rims will eventually be removed n replaced with fat white walls to give it that rat look. im undecided on either bagging it or just lowering it also if anyone has parts for this let me know im in need of a few trims, front windshield, n steering column... first pic is how it was when i got it second is the interior third before i dropped the engine in forth with the engine in thats how it sits n the last one after i put the blocks on the rear
The wheels should be the first thing to go... Actually using the word Rat here should be the first change!!!
