Any one do a dual master conversion drumsbrakes on a 53 olds 88 under the floor any suggestions would be appreciated.
Martin_F did a conversion on his Olds but with discs. Look up his thread and it may give you some hints.
If your Olds is like my 59, it will have the booster/mc mounted under the steering gear. You probably could mount a dual MC to the Moraine or Bendix booster, but filling the MC might be a problem. Also the MC would sit at an angle.
Thanks D2 found a thread from a hamber really good set up https://www.jalopyjournal.com/forum/posts/12097140/
