Anyone know the factory specs on the timing on this one. 10 degree retard, advance, yada yada...........
Set your points at .024-.026, timing is set at 0 degrees as per the Ford Shop Manual.Also sent you an invite to the 1952-56 Ford social group,do a "new guy" intro.this a very active group with lots of info on the 52-56 Fords,a lot of '53's there to check out.
