Projects 53 Ford customline 302/ T5 swap ideas
Discussion in 'The Hokey Ass Message Board' started by Adam lebuff, Oct 22, 2018.
  1. Adam lebuff
    Adam lebuff
    I have a 1953 customline. Just picked up a 302 and trying to find a t5 to mount up with it. What motor mounts have you guys fabed up and which t5 tranny should I use. Mustang or f-150
    WTK likes this.
  2. evintho
    evintho
  3. anthony myrick
    anthony myrick
    from al
    the truck had a t5?
    I thought the truck was a mazada built trans
    the car one has better gear ratios and is smaller in size
    I vote car
  4. ffr1222k
    ffr1222k
    You should join the 52 thru 59 ford social forum. If you click the icon next to the search function and pick social forums and then pick brands you will see the group. You will find this group to be very helpful.
    The Mustang transmission would be the better choice.
    JeffB2 likes this.
  5. Use the Mustang T-5 the truck transmission is different.
    I used 84 Mustang motor mounts with my swap. HRP
  6. Adam lebuff
    Adam lebuff
    I’m wondering in regards to the position of the shifter on the t5. I know the truck t5 position is in the middle vs the end off the tail housing. Would my bench seat still work with the mustang t5?
  7. ffr1222k
    ffr1222k
    Look at Hotrodprimer build thread in his signature. You can see his shifter location in a picture on page 14.
  8. Schwanke Engines
    Schwanke Engines
    Use Speedway's Weld in biscuit style mounts, we use them on every build very easy to custom fit them, as far as the Trans goes, Get the Mustang T5 and then grab the S10 Rear housing and shifter location for best fitment into the car if keeping the bench seat.
  9. Bench seat/T-5 transmission in a '54 Ford.
    I used a old Hurst stick and tilted it forward to clear the seat when my wife is driving with the seat in the forward position. HRP
    mikhett likes this.
  10. Adam lebuff
    Adam lebuff
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    WHOA!!! The O.P. has a '53 Ford the link here is from my Album for a '54 Ford mounts are night and day different, 1954-59 can use the mounts in this link but if you have a 1952-53 car you will want this. https://butchscoolstuff.com/52-53-ford-car-15-sb-ford-engine-transmission-mount-kit-2501cpb/ NOTE: I have sent Butch's pictures of SBF installations and they have NOT changed the text listed with the kit,ONLY the Ford AOD will sit dead on the stock transmission cross member if you have a T-5 or C4 you will need an extension plate shown below posted by one of our 1952-59 Ford Social Group members today. 1-gas.jpeg
  12. There is nothing wrong with the F-150 5 Speed (Also found in Thunderbirds and Cougars). It is a Mazda built M5-R2 transmission and can generally take a bit more torque then a standard Mustang T-5. The M5-R2 shifter is also further forward than the T5 shifter, that will typically work better in our old cars. I run one in my '51 F-1 and am very happy with it. They get a bad rap because of hard shifting that results from worn shift rails and bushings. It is a fairly straight forward repair to correct the problem. I have typically found that M5-R2's are also cheaper since they are not as prized by the hot rod community.
  13. Truckdoctor Andy
    Truckdoctor Andy
    The Mazda build M5-OD transmission in the F-150 is a good transmission! My 16 year nephew hasn’t hurt it yet! If you decide to go that way, send me a PM and I have a Hurst Shifter for the F-150 transmission. I bought an O/T 1990 F-150 for my Dad and the Hurst was installed in the truck, shifted great, just hard for Dad to use as a D/D.
