Projects '53 Chevy truck - My crazy project
Discussion in 'The Hokey Ass Message Board' started by orula, Mar 8, 2011.
  1. orula
    orula
    Thank you so much Mr48Chev,
    this document will be of great help to me.
    Many thanks
    Frank
  2. orula
    orula
    Hello to all,
    about the windshield.... I'm reminded of an event that happened to me during a reversal of the cab.
    I fell on the cabin floor and has crushed the middle.
    May have reduced the space as shown by the arrow...?
    Please someone tell me the exact measurement from the edge of the windshield above the one below.
    Any help would be greatly appreciated
    Thank you so much man
  3. oldman2
    oldman2
    Frank, the assembly manual shows this to be 15.16". I checked an old cab that still has the rubber in it. From the top of the rubber (top of cab) to the bottom of the rubber (at cowl) this dimension is 16.625". Hope this helps, or someone else chims in with more info....Jim
  4. orula
    orula
    Thank you so much Jim :),
    your help is always valuable.
    Later I go to see my measurements.
    Many thanks
    Frank
  5. yaidunno
    yaidunno
    from Wisconsin
    Frank, i just measured my cab (no glass or rubber) and came up with 15.125 inches roughly. I see in the photo of the cab on its roof, that the center windshield pillar is bent. I wonder if you dont have the roof fully pushed back out?
  6. orula
    orula
    Hi Yaidunno,
    I tried to put in place as it was before but with the center beam
    is not easy. Perhaps nothing has happened but I doubt it came because the windshield does not fit well. Maybe the rubber needs to be changed ... I do not know.
    Many many thanks for your help
    Frank
  7. Chevy54
    Chevy54
    from Orange, CA
    Great progress Frank, Did I miss something.... How did you end up with California plates? They look good on it!
  8. orula
    orula
    Hi Eric,
    thanks.
    Plates were already installed on the truck when I bought it because it comes from California. Unfortunately I can not leave and I'll have to replace them with Italian license plates :(.
    Soon there will be new updates ;)
    Thank yo so much
    Frank
  9. oldman2
    oldman2
    We will be waiting for the updates....Jim
  10. TruckBizz
    TruckBizz
    Wow Orula your truck is awesome!
  11. orula
    orula
    Many thanks Logic :)
  12. oldman2
    oldman2
    Hey Frank, anything happening worth posting, we don't want you to think we forgot about you:);):rolleyes:....Jim
  13. orula
    orula
    :) Thank you so much Jim,
    I'm working and soon I can document with pictures :).
    I will not disappoint :)
    Frank
  14. oldman2
    oldman2
    You have NOT disappointed us yet, I'm sure we all will enjoy what comes next:cool:...Jim
  15. shtterbug8
    shtterbug8
    so was that windsheild brace bent? just curious
  16. orula
    orula
    Shtterbug8 no, not yet :).
    I'm working on other things but soon I will return to the windshield.
    Many thanks
    Frank
  17. orula
    orula
    Hello guys, some little update :).
    This morning came the Ididit Steering Column and I immediately
    installed on the truck.
    This is a paintable column and will be painted white like the dash
    Air Ride installed. Ride Tech Shockwave 8000 series come
    in a few days to complete the work
  18. BANDITO
    BANDITO
    Nice work Frank!!!!
  19. n847
    n847
    Wow...It just keeps getting better!
  20. oldman2
    oldman2
    Frank, that air ride systems looks suuuuper, nice job....Jim
  21. orula
    orula
    Jim many thanks :)
  22. Are you just starting to make your steering connections this late in the build?
  23. orula
    orula
    65Standard no :),
    I'm late for work with other commitments.
    Until I had the column could not buy the linkage.
    Will I need to install 3 u-joint and 1 support bearing to go around the headers.
  24. Murch
    Murch
    Just got caught back up on your build, awesome! I hope you get the windshield figured out, wish I could help, but keep on plugging away and everything will come together. Great work!
    Murch.
  25. orula
    orula
    Murch, thanks,
    with a little patience I will solve the problem of windshield :).
    Frank
  26. hotrod 49
    hotrod 49
    Dude, good news! I was just having a conversation with my glass guy (been at glass for 50yrs.) and were talking about how my one windshield trim didn't fit like the other side. He noticed the print on the glass and told me the one company always cuts their glass on the big side! He was going to take it out and grind it down and I told him not to worry about it at the moment. Then I thought of you! I think the glass is too big! See if you can find an original to compare yours with. Just had to let you know!
  27. orula
    orula
    Hi Hotrod49,
    thank you so much for thinking of me.
    I compared the original and the new windows are the same size.
    It great nor small, are identical.... :confused:.
    I might cut both the glass in the top center...only 2 mm.....
    is an attempt that I do.
    Thank you very much for your time :)
    Frank
  28. good luck with the glass. I have seen cabs become disfigured from being set on the top, side, and the back. while people weld panels in. sanding the glass might be the best idea.
  29. orula
    orula
    Many thanks Pdunn10
  30. hotrod 49
    hotrod 49
    Was it original (OEM) or just the glass that was in the the truck when you got it? I ask because the bigger glass will fit on its own, just not with the deluxe rubber and trim!
