Projects '53 Chevy truck - My crazy project
Discussion in 'The Hokey Ass Message Board' started by orula, Mar 8, 2011.
  1. 38zephyr
    38zephyr
    Glass and trim in the rubber , then install as one unit .
  2. orula
    orula
    Many thanks Zephyr. 9 times I have installed the glass (both) in the rubber and after the SS trim. I'll try doing the opposite, let's see what happens :).
    Many thanks for your help
    Frank
  3. 38zephyr
    38zephyr
    That's the problem , I did the same thing and it won't work . Let me know if you get it this way . Good luck , it will work !
  4. I can't believe I missed this. What a beautiful truck! Orula, you do some fine work. I can hardly wait to see it finished. Good luck!
  5. orula
    orula
    Many thanks Zephyr, I will do my best :)
  6. orula
    orula
    I also :)...a few more months of work.
    Many thanks
  7. Fringe
    Fringe
    from Sacramento
    Awesome.....Subscribed
  8. orula
    orula
    Hello guys,
    I'm tired of trying, today was the tenth attempt....
    with silicone spray was much better
    I do not understand why remain open both corners of the rubber bottom .... as shown in pics
    What should I do?
    Many thanks
  9. Hank
    Hank
    from Wisconsin
    Is the gasket upside down? The curves are different on the top and bottom of the glass.
  10. orula
    orula
    Hi Hank,
    you say that I have mistaken the direction of the gasket?
    Yet I have already done this attempt,
    but tomorrow I try to run even the gasket.
    Many thanks for yor help
  11. PaulD
    PaulD
    It looks to me that the glass is slightly too large. Can you get a class fitter to come aroung and have a look?
  12. orula
    orula
    Hi PaulD, unfortunately, here there are no class fitter.
    I also thought that the glasses were too big but I measured his old glasses and they are the same size.
    Before it was installed with a gasket without S S trim.
    Today I thought to cut the glass, but I do not know how to cut.
    Many thanks for your help.
    Frank
  13. Mr48chev
    Frank there should be a few glass shops in Rome that can use a belt sander to trim the glass to fit. If it is laminated glass that is.
  14. Russian
    Russian
    If rubber around the glass is NEW, than that's why it's like that around the corners, the rubber don't have "memory" to go around corners OR rubber is more thicker than original in between glass and body and it seems like glass is bigger (and it's not) if the window is where it suppose to be (in line with metal edge for rubber all around) only way to resolve Your problem is to get the window out, put the rubber on it, warm up the rubber (don't over do it) and start to show where it suppose to be (be careful, you can leave finger inprints) use something that don't leave indentations and masking tape can help You keeping the rubber where You want it to be... Hope this helps
  15. orula
    orula
    Hi Mr48, yes, I can find a shop with the belt sender the glasses but I do not know where to cut ... perhaps in the middle? (as the pics below)
    I smooth 2 mm for each glass?
    In fact, the seal at the center not supported well on the central crossbar.....
  16. orula
    orula
    Hi Russian,
    many thanks for you help. Saturday I still....
  17. slick39
    slick39
    from dallas ,ga
  18. "Whitey Ford" 62 Uni
    man this thing is beautiful....i like the white too.
  19. Salty
    Salty
    from Florida
    orula, I wish I had some usefull information to impart on your glass Delma....I unfortunately do not...mine also had the same problem when I removed the glass and hopefully my glass guy can sort it out....that said you may want to pm Glassguy here on the HAMB he may be able to give you some more tips.....looking good friend....keep it up.
  20. orula
    orula
    Many thanks Salty, thank you very much for your help. I send now a Pm to Glassguy.
    Thanks
  21. RayMiller
    RayMiller
    Don't know how I missed the fact that you made it a 3 window from a 5 that is insane! Can't wait to see that one done, superior work. Ray
  22. orula
    orula
    :D :D :D
    Thanx Ray
    Many thanks to all
  23. I'm late to the game on this build and I don't know why! Great work Orula! Keep it up!
  24. sickytwisted
    sickytwisted
    Did we get the glass to fit yet? I think it's a poorly made gasket, which, unfortunately, most are. Sorry about this man. I'd love to know how you resolve this.
  25. orula
    orula
    Thanks Sickytwisted,
    this week I really have to install the windshield because many parts are coming and want to continue my project.
    I hope they cut the glass from 2 mm to be the final solution.
    Thanks for your input.
    Frank
  26. sfort
    sfort
    from texas
    Orula that site i gave you said to install glass trim and rubber assembled as one piece.
  27. sickytwisted
    sickytwisted
    Yeah, just so you know, I've been following this thread (as a lot of people are). I'd love to know if that cut solves your problem.
  28. Nuvolari
    Nuvolari
    from Italy
    ahhh! we proceed in secret! ...;)
  29. orula
    orula
    Hi Nuvo,
    is true :D, but I'll be back soon.
  30. orula
    orula
    Again this week to think.... and then cut the glass ...:D
    What can happen??
    At most I buy new glasses :D
    Thanks for your interest
