So I actually have a 150, scored some 210 quarter trim from the classifieds here and would like to get some help from any 210 owners here. What I need to know is how many holes and the spacing to drill. Doesn't have to be down to the thousandths of an inch. Just wondering if anyone here has a 210 with the trim off and could measure the hole spacing from the door opening back toward the rear. Here's a pic that hopefully shows what I mean: Notice, it's a 150 therefore never had any trim holes on the rear quarter. Thanks in advance!
I am filling mine in, but I can get you some measurements at lunch. I know there are the little holes above the wheel well that screw in, as you cant get to the hole inside due to the inner wheel well.
OK, Heres what I found: 1- 1.25 2- 8.5 3- 15.75 4- 23.25 * 5- 31 * 6- 38.25 * 7- 45.75 8- 53 9- 60 10- 69.5 Like I said earlier, the three with the asterics * have a small screw hole. It has an exterior clip that screws on, rather than goes all the way thru, as you cannot access them from inside. I shot a pic for example, but its had to tell as im trying to scrape all the lead out of this panel to repair it. Hope this helps!
