52 pontiac catalina/chieftan 2dr,ht..running,driving...hotrod project
Discussion in 'Cars For Sale' started by hotrodgypsy, Aug 17, 2015.
  1. hotrodgypsy
    hotrodgypsy
    from reading,pa
    City: Reading
    State: Pennsylvania
    Price: $8800..00
    rare 52 catalina 2dr ht...runs , drives,titled in pa as antique...clear title in my name.....selling to help raise transplant medication monies...im a kidney/pancreas recipient....Pontian drivetrain...350/350 combo...10 bolt rear(308 gears)...painless 12v wiring kit installed...new steelies with newer radial tires....black interior....dual exhaust about 1 yr old...I originally didn't build this car..i optain projects work on then to raise my monies needed,,im a retired ase certified mechanic and go over the cars the best I can.. most need some straightening out...new...electric fans,carb,stsrted,firewall mounted power booster and dual master cylinder......stock steering(steering box has some play, may need a rebuild. .still drivable)power drum brakes, all rebuilt.....new coolant recovery system and radiator....recently restored/repaired gas tank with new 0-30ohm sending unit and working factory guage with voltage reducer....monte carlo tilt wheel, guage trio, dash mounted tack....glass is good for its age...most stainless. .has extra parts and chrome reverse wheels in the trunk...new shocks...new battery....new battery cables and battery disconnect switch....everything works...led lights......GREAT START,HARD WORK DONE,DRIVE AS IS OR PERSONALIZE IT .....new drive shaft with new u-joints....
