need a rebuild kit, believe this is a holley 1901. Do I need to know anything more then that for the kit, is there different varietys of the 1901? sources I see say the 52 lincoln had the 1901-FF Heres the numbers I could find, stamped on the top 12R815 stamped along the back, these are difficult to get to and read but best I can tell it says EAD 9510 D2 List 758
I think if you check a little closer you will find the List number is 728, not 758. The EAD-9510-D2 or the list 728 is sufficient identification. Jon.
any suggested suppliers for a rebuild kit? Is this a 1901 and will any 1901 kit work? googling those other numbers I find very little but I find quite a bit searching for holley 1901
